Extend multiple return value syntax functions to be more usable
The addition of multiple return value syntax functions in IP8 were a very nice addition. Now you can finally have a nice way of returning multiple values and don't need pass-by-reference parameters anymore.
This makes it also feasible to have functions return a string and a variable like in
Function [variable real, string text] GetValue()
return 1, "abcd"
One example for such functions are generic getters which can return a string or a variable. The call site for functions like that do look a bit odd still, if you only care about one value.
Function DoStuff()
variable var
string junk
[var, junk] = GetValue()
Now we come to my request :)
I would like to have a way to select one of the multiple return values at the call site. Something like
Function DoStuff()
variable var
var = GetValue().num
sprang to mind. This would make the call site less cluttered.
And would also allow to have MRS functions return correctly typed waves as in
Function [WAVE num, WAVE/T text] GetWave()
Make/FREE num = { 1 }
Make/FREE/T text = { "abcd" }
Function DoStuff()
WAVE num = GetWave().num
WAVE/T text = GetWave().text
I don't have very good reasons for the ".$name" syntax addition and are happy to be persuaded to even better syntaxes.
Have you seen in IP9 that you can declare the parameters in-line? i.e:
I use this a lot now..... though it is not quite what you're requesting it does clean up the syntax quite a bit.
June 15, 2021 at 08:49 am - Permalink
Jeep, I've seen that. And this helps already, but does not go far enough IMHO.
June 15, 2021 at 08:58 am - Permalink
Doesn't MatLab use a syntax something like
to skip or throw away unneeded return values? Would something like that help?
One problem with the ".$name" syntax would arise for a function returning more than one value of the same type.
June 15, 2021 at 10:47 am - Permalink
@jtigor - whatever this so-called 'matlab' is looks like it has a sensible solution for the multiple return syntax ;)
In all seriousness I like the matlab way as you can see better what the code is doing rather than the python style.
June 15, 2021 at 11:58 am - Permalink
In reply to @jtigor - whatever this so… by cpr
jtigorI hesitated to make that reference...
June 15, 2021 at 03:06 pm - Permalink
I'm also fine with just leaving it off. But of course this would need to work with anyone entry.
My syntax suggestion uses the name of the MRS return value and not the type. And the name is unique. Does that make sense?
June 15, 2021 at 04:24 pm - Permalink
In reply to I'm also fine with just… by thomas_braun
jtigorYes. I completely missed that. Makes sense.
June 16, 2021 at 04:40 am - Permalink
Perhaps these look prettier to you:
June 16, 2021 at 08:24 am - Permalink
@aclight: Thanks for reminding me about this alternative syntax for MRS functions.
At least for me this does not help, as it uses pass-by-references parameters explicitly which get's confusing quickly if you also have normal parameters.
June 17, 2021 at 02:37 am - Permalink
What I understand is that under the hood, the multiple-return syntax is using pass-by-reference parameters, so the parameters have to be declared ahead of time -- whether in their own lines (ala IP8) or using the condensed single-line version offered by IP9.
In Matlab, you can define a function [a, b, c] = f(x,y) and then you can assign to local variables only those return values you care about. (@thomas_braun, I think that's what you're after... am I right?) So, for example, you can declare
and when calling function f you can assign any of the following:
(Is there a way in Matlab to skip assigning values from the middle, like v? Even if not, Matlab does not require declarations, which makes it easy to just assign it to a dummy variable and ignore it.)
What would an optional return MRS syntax in Igor look like, and how would it work? If an output variable is not provided, perhaps Igor could detect that the reference is null and maybe create a valid local variable or free wave (as the case may be) to be used in its place during the function run (in case the function uses that parameter or assigns to it). So if a function is defined as follows:
Then maybe if you don't care about assigning v to a local variable you could make a call like:
or better:
If this is possible, is something like this what you had in mind?
You also mentioned something along the lines of "var = GetValue().num". I do like the compactness of that syntax. You would want to support more than just one output, since you certainly wouldn't want to call GetValue() twice just to get .num and .text. That suggests having the MRS support Struct outputs -- but at that point, it seems to make more sense to simply pass a Struct by reference as a regular variable. That's just my two cents.
I do like the idea of having optional return values.
June 18, 2021 at 09:10 pm - Permalink
Yes!
Yes this would be an option.
The idea behind the dot syntax is that you can just select one return value from the existing ones. So this would be optional only. If you need all return values you can just grab these with the existing syntax.
What the matlab solution has in advantage of the dot proposal is that you can ignore multiple values while fetching more than one. The dot proposal on the other hand has/could have the advantage that the return value can be used like a variable. So if the returned value is a wave and you get that via .wv you can immediately start indexing it as in .wv[5].
June 29, 2021 at 03:20 am - Permalink
