    output of Multi-Peak Fit
Dear all,
The output of Multi-Peak Fit of Igor is written in the file name "MPF2_ResultsListWave" in which each column has a header "MPF2_ResultsListWave[][1] , MPF2_ResultsListWave[][2]..... . when I print this file in my macro, all columns are printed and the Area which is in the column number 6, is printed as:
"MPF2_ResultsListWave[0][6]= {"2153.8","8328.4","16755","9497.3","11676","12375","8640.9","18019","19278","7782.2","343.11","26873","32176"}"
but when I tried to write it in a wave such as w = Coefs_Name2[0][6], it is not working. could you please help me how can I write column number 6 in a wave?
Best
Ali
here are two ways:
June 18, 2021 at 06:16 am - Permalink
The problem here is that MPF2_ResultsListWave is a text wave where the numbers are written as text. To write the results into a numerical wave you need to convert the text into values. You can use the function str2num() for this:
If you are planning to upgrade to Igor 9 you will find that there are other, more convenient, ways to export the results in the newest Multipeak Fit version. :)
June 18, 2021 at 06:20 am - Permalink
thanks Chozo for clarifying this!
June 18, 2021 at 08:29 am - Permalink
