Adding wave to Z wave in image plot
Hello all,
I have several image plots from time resolved spectrospy. The X and Y axis are time and wavelength and Z is absorption change with time. Besides the original data I need to add to the Z data, after some processing in Igor Pro, another spectrum with different spectral range. I could do this outside Igor but it's added work that seems unnecessary since we can add waves easily in Igor.
In short, I need to know if it's possible to add to the Z data, in a image plot, a single wave like using Wave Arithmetic panel?
Thanks in advance,
Filipe Velosa
johnweeks
As long as the waves have the same dimensions:
image1 += image2[p][q]
DisplayHelpTopic "Multidimensional Wave Assignment"
wings
Yes, It is possible.
If the spectrum to be added has the same dimensions with the original data, things is quite simple, you can just do it as johnweeks's method.
If the waves have different dimensions(different dimension range,different size,different sample intervals), things become a little complicated. You can try the following codes to see whether or not it can meet your needs.
Function/wave AddTwoWave(w1,w2,flag)
	wave w1   //the original image
	wave w2   //the image to be added
	Variable flag //0:create new wave, named by w_tmp; 1:overwrite w1
	Variable x0,dx,nx,y0,dy,ny
	[x0,dx,nx]=GetWavesRangeMax(w1,w2,0)
	[y0,dy,ny]=GetWavesRangeMax(w1,w2,1)
	Make/O/N=(nx,ny) w_tmp
	SetScale/P x,x0,dx,w_tmp
	SetScale/P y,y0,dy,w_tmp
	w_tmp=GetInterp2dValue(w1,x,y)+GetInterp2dValue(w2,x,y)
	if(0==flag)
		return w_tmp
		Duplicate/O w_tmp w1
		Killwaves/Z w_tmp
		return w1
Function [Variable v0,Variable d,Variable n]GetWavesRangeMax(wave w1,wave w2,Variable dim)
	Variable vmin1,d1,vmax1,vmin2,d2,vmax2
	[vmin1,d1,vmax1]=GetScaleInfo(w1,dim)
	[vmin2,d2,vmax2]=GetScaleInfo(w2,dim)
	v0=min(vmin1,vmin2)
	d=min(d1,d2)
	n=floor((max(vmax1,vmax2)-v0)/d)+1
Function [Variable v0,Variable d,Variable v1] GetScaleInfo(wave w,variable dim)
	v0=dimoffset(w,dim)
	d=dimdelta(w,dim)
	v1=v0+(dimsize(w,dim)-1)*d
Function GetInterp2dValue(w,x,y) //if (x,y) is out scale index range, return 0
	wave w                        //else,return interpolated value
	variable x,y
	Variable v0=interp2d(w,x,y)
	if(2==numtype(v0))
	return v0
