five or higher dimensional waves
maru
Tue, 12/07/2021 - 09:58 pm
Is it possible to create a wave with five or higher dimensions?
I have physical properties, e.g., light intensities, measured at different conditions, such as temperature, geometric angle, solute concentration, etc.
I want to store, display and analyze the intensities flexibly. I thought a multiple dimension wave would be a suitable container for the data.
I guess, since all commands I know of working with waves support up to four dimensions, the answer is no. So you would need to work around this and use the 4 most important parameters in one wave. But then, I am also not sure it makes things easier when working with so many dimensions in one wave. You could emulate this by having the fifth (and higher dimensions) as a series of waves in a folder (and even subfolders). Then this folder would represent your 'complete' dataset.
December 7, 2021 at 11:31 pm - Permalink
No, Igor supports only 4 dimensions in waves. Even then, many operations don't work at all, or don't work in a terribly useful way, if your wave is > 1 dimension.
December 8, 2021 at 08:36 am - Permalink
I have not encountered practical applications that required true 5D data sets. With increasing dimensionality the size of the waves increases and frequently becomes difficult to manage. This requires some planning and depends on your application. There are two general workarounds that come to mind:
If you are working with dimensions of sizes dim[0],dim[1]... choose the smallest dimension (say dim[3]) and split your data into dim[3] 4D waves. This will solve the representation of your data but you still end up with 4D waves that are not very useful for plotting or analysis.
The second approach, which could be useful if your data set is sampled on 4D 'rectangular' grid, is to save the data as a 1D wave and write a short function that returns the appropriate index:
Variable theRow,theCol,theLayer,theChunk,theSuperChunk,rows,cols,layers,chunks,superChunks
Wave inWave
Variable layerSize=rows*cols
Variable chunkSize=layerSize*layers
Variable offset=theRow+theCol*rows+theLayer*layerSize+theChunk*chunkSize+theSuperChunk*(chunkSize*chunks)
return inWave[offset]
I hope this helps,
December 8, 2021 at 10:37 am - Permalink
Thank you for the comments and suggestions. I understood that Igor could handle up to 4 dimensions, and it is not good to analyze such high dimension waves.
Getting a 1D wave from the multi-dimension wave is what I attempted. However, as there is a limitation in the wave's dimension, I think maybe I should store the multi-dimension data in an XML file and then get the 1D wave from there.
December 8, 2021 at 03:58 pm - Permalink
In reply to Thank you for the comments… by maru
Keep in mind that if you are storing data in a text based format, the cost to parse that text and convert it into numerical values may be significant, particularly if you need to do this to the same data over and over.
December 9, 2021 at 07:23 am - Permalink
Could you explain what is the specific limitation here? I assume your data are stored in some file format on disk. Can you tell us what file format that is?
Though possible, I can't imagine that you would have a 5D dataset that is not sampled on a regular grid. If that is the case, conversion into a 1D Igor wave should be straightforward.
December 9, 2021 at 10:09 am - Permalink
