fitting with weights given by covariance matrix
rk
Mon, 12/20/2021 - 04:40 pm
I wonder if there is a possibility to use a full covariance matrix for weighted regression instead of using a 1D wave with values of standard deviation (or inverse of standard deviation square). I couldn't find this information in the manual. I am using Igor Pro 7.
I have data points characterized by significant off-diagonal elements of a covariance matrix (for some points correlation is even ~0.9). Therefore, I believe I should include information about covariance in my analysis.
I will be grateful for comments.
Regards,
Rafal
Igor doesn't support a covariance matrix yet. Sorry.
December 20, 2021 at 05:02 pm - Permalink
In reply to Igor doesn't support a… by johnweeks
Thank you for your response. I hope that this feature will appear soon. I don't think it should be hard to implement this, as anyway (at least I believe so) fit optimization is done using matrix formalism.
December 20, 2021 at 06:42 pm - Permalink
The difficulties have to do as much with the public interface as with the math. We could require you to provide the full covariance matrix, but that's N^2 elements, and that gets big fast. In most cases, I think the off-diagonal elements are likely to be the same for a given diagonal, so perhaps it would be possible to accept a wave containing one element for each non-zero diagonal. But that decreases generality.
In any case, I'm afraid this would have to wait for at least Igor 10.
December 21, 2021 at 09:20 am - Permalink
