Changing the date format from MM/DD/YYYY to DD/MM/YYYY
How can I change the date format on the x-axis of my graphs to DD/MM/YYYY? Currently, the format is MM/DD/YYYY.
Second question, is it possible to reduce the tick values to DD/MM instead of DD/MM/YYYY?
Kindly let me know.
Sincerely,
Peeyush
Nevermind, I worked it out..
double click the bottom axis - Ticks and Grids tab - Date format - Other- select format.
December 22, 2021 at 01:53 pm - Permalink
