Programming help for new user
I'm new to Igor (and programming!) and want to apologize in advance for the basic question. I've just started going through the manual but have a somewhat urgent deadline and would be very grateful for some help pointing me in the right direction.
I have two waves, x and V. I need to find the maximum V for every group of 32 points. These maxima would ideally be interpolated, and I should note that every group of points takes the shape of a smooth, yet antisymmetric peak. I then need to make a wave of the x-values corresponding to these maximum V-values. Because I'm working with a high volume of data, manually plotting/calculating this is not feasible. Every set of 32 x-values is identical.
Where would be the best place to start in order to figure this out quickly? I got Igor today and have been going through the tutorial and programming section to get started. I still feel like I'm a long way away from being able to write a program from scratch and am not sure how to go about my main task.
July 22, 2010 at 10:50 pm - Permalink
Wow, thank you so much. I really appreciate it!!
July 26, 2010 at 03:47 pm - Permalink
