Built-in FFT routine suddenly returns NaNs
I was repeatedly and successfully using the built-in Fourier Transforms dialog box available through the Analysis menu, when suddenly is stopped working, in the sense that the automatically generated graph was blank. When I use the Command Line to print out one of the points of the automatically generated FFT wave, it shows NaN.
johnweeks
It is likely that the input data contains one or more NaNs. An FFT for each point depends on all the input points, so if any point in the input is NaN you will get output that is all NaNs.
In the Data Browser (Data->Data Browser) find your input wave. Select it, and then click on the "Sigma" icon below the list of waves. If numNaNs is not zero, that is the problem.
johnweeks
It's a fairly common problem. On the face of it, it's surprising that a single NaN causes the entire output to be NaN. But that's how FFT works!
