Using Funcfit with constrains
Hi. How can I use /C to add constrains to a custom fitting function?
If I follow the example from "Fitting with Constraints" I get an error saying "expecting fitting function".
Thanks.
chozo
Can you post the command you are trying to execute? This error does not sound like some problem with constraints but rather a syntax error. Maybe you don't have the /C flag after your input wave? We need a bit more information to judge what is going on.
IVP
Make/O/D/N=2/O W_coef
Make/O/T/N=2 T_Constraints
T_Constraints[0] = {"K1 > 0","K1 < 65536"}
FuncFit/Q/N=1/X=1/W=2/C=T_Constraints MyFitFunc W_coef MyFitWave
The error I am getting is at /C saying "Expected fitting function"
Thanks.
ilavsky
FuncFit/Q/N=1/W=2/X=1   MyFitFunc W_coef MyFitWave  /C=T_Constraints
This should work. /C must be behind the MyFitFunc W_coef MyFitWave
