Question on creating a single wave
Hi Guys,
I tried to make a single wave which has 3332 data points (from 0 to 3331) and has a constant value of 1282.5 for each data points.
I used the 'make wave..' menu but and set the data values as in the image.
But I was not able to create it. When I append it onto the table, it just shows a column of all 0 in every data point.
Cheers,
awirsing
Use a simple wave assignment:
YourWave = 1282.5
The data properties, that you showed in the image is only useful for storing info about the wave such as data scaling and the conditions under which the data were recorded, but have absolutely no effect on the data.
For exapmle if the wave holds a waveform read from a oszillscope you could enter in these fields "V" and -0.1, 0.1 (if the scope was set to a range from -0.1 to 0.1 V).
aclight
To be more specific, you should use this command:
Make/N=(3332) myWave = 1282.5
For more information on wave scaling and how to create a wave, execute the following lines in Igor's command line:
DisplayHelpTopic "Make"
DisplayHelpTopic "SetScale"
hrodstein
You were setting the "data full scale" property, not the data.
The data full scale property is just for documenting what "full scale" of the data is. For example, if you acquired the data from an oscilloscope set to the +/- 10V scale, you could set the data full scale property to document that fact. Otherwise it is not used.
For details execute this:
DisplayHelpTopic "Changing Dimension and Data Scaling"
and read down through the paragraph that explains "data full scale".
Igor_user
aclight wrote: To be more specific, you should use this command:
Cheers, aclight!
