symbolic paths and opening files
Here is the Macro I wrote. It calls loadtrace on all files in folder called pathname, then load and process all files in a given folder.
However, when I type the command for example loadODMRtraces("C:\Users\BurkeLab\Desktop\070824"), it gives me an error saying that no symbolic path of that name. How could I fix this bug. Thanks!
Macro loadODMRtraces(pathname)
// calls loadtrace on all files in folder called pathname
// Load and process all files in a given folder.
// The folder is specified by pathName which becomes a dialog
// if no input is given.
// YOU MUST INCLUDE #include <Strings as Lists>
// SOMEWHERE IN YOUR PROCEDURE, AS THIS MACRO
// CALLS SUBROUTINES FROM THAT INCLUDE FILE.
String pathName // name of symbolic path or "" to get dialog
variable/d numfiles
String filename
PauseUpdate; Silent 1 // Processing files . . .
Variable index=0
variable/d tracenum
if (strlen(pathName)==0) // if no path specified, create one
NewPath/O temporaryPath // this will put up a dialog
pathName = "temporaryPath"
print IndexedFile($pathName,-1,"????")
do
fileName = IndexedFile($pathName, index, ".csv")
if (strlen(fileName)==0)
break // break out of loop
// Assume file name is of form mmddyyc.xxxx, where x is a number. Strip off the number.
tracenum = str2num(filename[7,10])
loadODMRtrace(tracenum,filename,pathname)
print index,filename,tracenum
index += 1
while(1)
if (Exists("temporaryPath")) // kill temp path if it exists
KillPath temporaryPath
EndMacro
You are confusing symbolic path names with file path values.
Enter this command for a more thorough explanation that I can give here:
DisplayHelpTopic "Symbolic Paths"
August 19, 2024 at 04:40 pm - Permalink
Also, this comment:
Is relevant to only a very ancient version of Igor, and hasn't been needed since Igor 3 or so.
Now, maybe loadODMRtrace() does rely on that ancient Strings as Lists procedure file; it should be updated to use the built-in functions such as StringFromList() and ItemsInList(), etc.
August 19, 2024 at 04:43 pm - Permalink
