Using my color table in f(z) selection menu
I have just used the easy to learn color wave editor to create my own color table but how do I get this into the menu to colorise traces using the 'set as f(z)' method in plots and to select from built in default color tables.
Use Color Table Waves instead of Color Tables. (It's a different radio button)
August 26, 2024 at 09:33 am - Permalink
I had already tried that but all the "colours" were black when I used it, so questioned how to do it.
I had used dBZ14 and changed the colour order. Saved it and then used as Color Table wave.
August 27, 2024 at 04:32 am - Permalink
Actually JIm I have found that I can directly edit the new color table wave as a table from the data browser working directly on my plots - this will serve my purpose.
August 27, 2024 at 05:10 am - Permalink
You may have already solved your problem, but in your attached images, I noticed you have 'After Last Color' set to black and the max value set to 15. The black colors you had been seeing might mean that most of the streamIDplotkey data is beyond 15.
August 27, 2024 at 08:23 am - Permalink
In reply to I had already tried that but… by Mike German
[quote=Mike German]
[/quote]
The color wave editor makes it way too easy to create a color wave that doesn't use the peculiar Igor standard of 0-65535 for color intensity. You probably created either an 8-bit color wave or a 0-1 color wave. You can convert it right in the editor.
September 3, 2024 at 12:37 pm - Permalink
Thanks, Jim, Ben and John for advice - I'm still working on it.
September 13, 2024 at 09:23 am - Permalink
