Folder Selector
This is my first code snippet, and is a little macro showing how to display a list of the first level folders. You can set as active any folder by double clicking on it. Future versions will work with different level folders. If you have suggestions please let me know.
#pragma rtGlobals=1		// Use modern global access method.
// Window Recreation
Window Folder_Selector() : Panel
	Makelist()
	NewPanel /W=(434,276,689,553) as "Folder Selector"
	SetDrawLayer UserBack
	DrawText 19,34,"Double click on the folder to set as active"
	ListBox list0,pos={19,52},size={75,132},proc=ListBox_G,frame=0
	ListBox list0,listWave=root:lista,mode= 2,selRow= 0
EndMacro
// List Box Control
Function ListBox_G(ctrlName,row,col,event) : ListBoxControl
	String ctrlName
	Variable row
	Variable col
	Variable event	//1=mouse down, 2=up, 3=dbl click, 4=cell select with mouse or keys
					//5=cell select with shift key, 6=begin edit, 7=end
	WAVE lista=root:lista
if (event == 3)
	String/G nombre			//name of the current Folder
	string cmd
	sprintf cmd," nombre = root:lista[%g]", row
	execute cmd
	if (cmpstr (nombre,"root:") == 0)
		setdatafolder root:
		nombre = "root:"+ nombre
		setdatafolder $nombre
	print nombre
// Folders List Function
Function Makelist()
string objName
variable n,i
i=0
n = CountObjects(":",4)
Make/O /T /N=(n+1) lista
lista[0] = "root:"
do
	objName = GetIndexedObjName(":", 4, i)
		if (strlen(objName) == 0)
		break
	lista[i+1]=objName
	i=i+1
	print i
while(1)
gfernandezv
if (event == 3)
	string cmd
	execute cmd
		setdatafolder root:
		nombre = "root:"+ "'"+nombre+"'"
works better whit liberal names.
johnweeks
	string cmd
	execute cmd
Why do you need the global variable and execute? Can't you do it this way:
	String nombre			//name of the current Folder
	nombre = lista[row]
