Extension gizmo voxelgram
First of all: I have not used Gizmo in the past. If my requests already exist and I haven't found them, please let me know.
1. Currently, voxelgram allows you to assign a color to values including a tolerance. I would like to see a continuous color scale like in NewImage. (examples: rainbow from 1 to 10 or grays auto to auto)
2. You can display the voxels as points or cubes. You can select the size of the voxels. I would like to be able to fill the volume to the neighbor (up to half the distance to the next neighbor. If there is no neighbor, the voxel should end at the data point + a set offset). Presumably, a limit would also be necessary for the distance at which neighbors are searched for.
3. I would like to see cursors for 3D space that could be used with the arrow keys for x and y, as well as two other keys for the z-plane.
4. I miss the option to insert areas that make parts below of the displayed volume transparent (for cross sections in x, y, z direction and a free one).
    4b. It would be best if you could place at the cross section cursors to read the data points.
5. Unfortunately, the export of 3D gizmo data is also limited. The videos look very blurry on Mac. I don't know if it's better on Windows. I would like to see improvements here.
But a 3D object may also be necessary for use in other documents. Perhaps in the future it will be possible to export a gizmo to a format that is compatible with MS Word, for example.
I know that these are a lot of requests and that they will certainly take time to implement. In my opinion, these features would be a significant improvement for Gizmo.
Igor
Hello Gregor,
1.  I don't understand your request.  Are you expecting to paint values within the tolerance with a range of colors? If so, do you expect the user to select an existing colortable to cover the range of tolerance?
2. A box size of 1/2 typically fills the range between voxels.  There is some internal code that attempts to remove duplicate facets on the matching boundaries.
3.  You can fashion a 3D cursor using Free Axis Cue.  The current version of Gizmo does not support a 3D mouse so there is no way to select and manually offset a 3D cursor but you can do so from a dialog or a control panel.
4.  There are some ways to create similar effects.  For example, you can use an arbitrary clipping plane (see Example Experiments:Visualization:Advanced:Clipping Demo).  Otherwise, the general application of transparency is by object.  You can make a selected part of your object transparent by applying the proper alpha to the object's color.
5.  Gizmo images are bitmaps and depend on your hardware.  You also have control over the default output resolution using ModifyGizmo with the keyword outputResFactor.
ggermer
1. Perhaps I can explain this better with an example:
I have a wave with three dimensions. Many data points are empty, but in some places values from 1 to 100 are entered.
I want to create a voxelgram to see the shape of the values, but also like to see the values in the voxelgram.
In the Gizo module, I can currently select 5 colors with a tolerance. All data points within the tolerance have the same color, while data points outside the tolerance have no color at all. In this case, the tolerance would be 10 and the colors would be for the values 10, 30, 50, 70, and 90. (And only five colors: red, orange, yellow, green and blue)
I could see the data much better if I could use a rainbow scale from 1 to 100. Just as I would do layer by layer in a NewImage. And that is exactly my request as a new feature.
2. Does this also apply if there are empty points (N) in the wave?
For example, 1 N 1 N N N 1 N 1
In this case, I could imagine wanting to define that the points should be connected until there are 3Ns between.
3. - 4. Thank you! Ich will have a look.
5. I will also take a look at these settings.
It would still be great if there was the option to implement a 3D export format. Something that you can rotate and view in another document. (But I realize that this may remain a dream.)
Igor
1.  The voxelgram was never intended to support a single range with different colors. Nothing keeps you from appending to Gizmo m different voxelgram objects each covering a unique value and a unique tolerance.
2.  If the presence of NaNs in your data gives rise to undesired effects, you could use the following approach:
variable minValue,maxValue,replacementValue
[minValue, maxValue] = WaveMinAndMax(your3DWave)
replacementValue=minValue-100
// or
// replacementValue=maxValue+100
MatrixOP/O aa=ReplaceNaNs(your3DWave,replacementValue)
Now plot a voxelgram of the wave aa.
5.  Some customers post videos of a rotating Gizmo plot which is fairly easy to do using Gizmo Menu->Create Movie...
ggermer
Recently, I have continued to work on NewGizmo and have found some ways to circumvent the limitations.
Unfortunately, I have not yet found a way to address two issues:
1. Rotation (using a vector) and translation (x,y,z) of a voxelgram. (Individual rotation/translation for each gizmo object.)
2. Using of other types of coordinate systems, e.g., cylindrical or spherical, for voxelgram also including any necessary rotation and translation.
I would like to kindly ask if there is a possibility to add these features to NewGizmo in the future.
Igor
All the cubes in a voxelgram are considered to be a single Gizmo object and they all obey the translation and rotation specified on the Display List.  I am guessing that you are asking for individual (rotation/translation) for each voxelgram cube.  If that it the case, this is unlikely to happen because you would need to provide e.g., rotation information for each voxel that matches the conditions specified in the object.  Unlike scatter plot where the scatter centers are specified by a triplet wave, there is no way to know in advance how many points are drawn by the voxelgram object.
It seems to me that the obvious workaround for this request is to convert the 3D scalar wave into a triplet wave for the X, Y and Z locations of the voxels that satisfy the selection condition.  You then plot this triplet wave as a scatter object which supports individual rotations/scaling, etc.
I'm curious about the request for other coordinate systems.  Can you give me an example application where a simple coordinate transformation does not solve the problem?
AG
ggermer
Sorry for the late reply.
I would like to rotate all voxels of one gizmo object. Not the individual voxels themselves.
Conversion is a possible solution, but not really ideal. It would be more of a grid that calculates the data values point by point. In cylindrical or polar coordinates, the shapes of the individual voxels are not cubes.
Is there a built-in function for transforming a wave from one coordinate system in another? Unfortunately, I haven't found anything yet.
Igor
It seems to me what what you are looking for is not available as such in a Voxelgram.  The Voxelgram object can either draw a point in 3D space (in which case rotation is meaningless) or draw a cube.  Igor does not have native support for cylindrical or spherical coordinates.  The basic data sampling uses a Cartesian system.  If we try to support Cylindrical system say (r, theta, z) you could fake the cube equivalent of a voxelgram using scatter with a Pie-wedge object.  This is not going to be very efficient but it should work.
I can't think of a way of extending this to Spherical coordinates because we have no native object that satisfies these requirements.
I suggest we take this off-line (you can contact me directly at support@wavemetrics.com) and please describe in detail or show me an example of what you are trying to accomplish.
AG
