Large integer value in numeric wave
I encountered an issue working with large integer value in numeric wave.
It appears that when the a number larger than 2^24 is stored in numeric wave, it can be off.
For example, I was expecting the values in wave0 to be 16777216, 16777217, 16777218, and 16777219 if I run the following commands. However, they are actually 16777216, 16777216, 16777218, and 16777220.
make/n=4 wave0
wave0 = p + 2^24
My question is, how do I handle this properly if I need the last digit precision.
make without /D creates a single-precision floating point number, which is a 32-bit value.
The mantissa part of a single-precision float is only 23 bits. The other 9 bits are sign and exponent:
A google AI result is correct:
A 32-bit single precision floating-point number, defined by the IEEE 754 standard, is formed by combining a 1-bit sign, an 8-bit biased exponent, and a 23-bit mantissa. The sign bit (0 for positive, 1 for negative) indicates the number's sign, the mantissa stores the significant digits of the number, and the exponent field contains a biased value (exponent + 127) to represent the number's magnitude.
The largest integer exactly representable in a single-precision (IEEE 754 binary32) floating-point number is 16,777,216 (2^24). While a single-precision float can store numbers up to approximately 3.4 x 10^38, it loses precision for integers larger than 2^24 (16,777,216) because its 24-bit significand (mantissa) is not large enough to hold all the bits of a larger integer precisely
Use Make/O/D to increase the mantissa size to 53 bits.
In general, I would not recommend using /L or /U unless you are dealing with binary logic or pure integer operations.  The problem with 64-bit integers is that they are not represented exactly by DP variables (over 53 bits).  Most computations in Igor are performed in DP so you really need to be careful when performing operations on 64-bit integer waves.  For example:
make/n=10/L ddd=2^54 // function not available for this number type
or
matrixop/o/p=1 aa=sum(ddd)  // does not support int64 waves
... and,
•make/L/O ddd=1<<55
•Variable/G a=ddd[0]
•Variable/G b=ddd[0]-1
•Print/D a-b
  0
So conversion to DP is problematic.  On the other hand, integer computation without conversion to DP works:
•ddd[0]-=1
•print/d ddd[1]-ddd[0]
  1
