FuncFit thinks complex y wave and real x wave have a different number of points
Hi all,
I'm trying to write an all-at-once fitting function for a frequency-domain measurement. I'm trying to use a 62-data-point complex y wave and a 62-data-point real-only x wave as the input, but I get an error saying that the x and y data contain a different number of points. Any ideas?
In the following code, I split up the output from the instrument (5 columns: frequency, X channel signal, error in X channel, Y channel signal, error in Y channel) into a wave for the x data (wF, the frequencies used) and the real and imaginary components of the signal (wX and wY, respectively), which get combined into a 1-dimensional complex-valued wave, wComplex. I then try to pass the complex-valued wComplex as the y data and wF as the x data for FitFunc, but it gives me the error, "error: X and Y data have different number of points."
I also wrote it to fit as the log of the function thinking it would save time, but honestly, even having 50000 simulated points in the all-at-once function is pretty fast, hence the weird shenanigans with the log and 10^x stuff.
Function SSMC_FreqFit(w0,wParam)
	WAVE w0,wParam
	Duplicate/FREE/O/R=[][0] w0, wF
	Duplicate/FREE/O/R=[][1] w0, wX
	Duplicate/FREE/O/R=[][3] w0, wY
	Variable NumFreqs = DimSize(w0,0)
	Make/C/O/N=(NumFreqs) wComplex
	wComplex[] = cmplx(wX[p],wY[p])
	String CFitName = NameOfWave(w0) + "_CFit"
	Duplicate/O wComplex,$CFitName
	WAVE wCFit = $CFitName
	WAVE ParamTable
	WAVE ParamHold
	String HoldStr = num2str(ParamHold[0]) + num2str(ParamHold[1]) + num2str(ParamHold[2]) + num2str(ParamHold[3]) + num2str(ParamHold[4]) + num2str(ParamHold[5]) + num2str(ParamHold[6]) + num2str(ParamHold[7]) + num2str(ParamHold[8])
	FuncFit/H=HoldStr SSMC_FreqFit_proc, ParamTable, wComplex /X=wF/D=wCFit
	String ParamOut = NameOfWave(w0) + "_Param"
	String ParamSOut = ParamOut + "_s"
	Duplicate/O wParam,$ParamOut
	WAVE W_sigma
	Duplicate/O W_sigma,$ParamSOut
	WAVE wParamOut = $ParamOut
	WAVE wParamSOut = $ParamSOut
	String OutName = NameOfWave(w0) + "_Fit"
	Duplicate/O w0,$OutName
	WAVE wOut = $OutName
	wOut[][0] = w0[p][0]
	wOut[][1] = real(wCFit[p])
	wOut[][2] = 0
	wOut[][3] = imag(wCFit[p])
	wOut[][4] = 0
Function SSMC_FreqFit_Proc(wcoef, yw, xw) :FitFunc
	WAVE wcoef
	WAVE/C yw
	WAVE xw
	Variable A0 = wcoef[0]
	Variable t0 = wcoef[1]
	Variable A1 = wcoef[2]
	Variable t1 = wcoef[3]
	Variable A2 = wcoef[4]
	Variable t2 = wcoef[5]
	Variable F0 = Log(wcoef[6])
	Variable F1 = Log(wcoef[7])
	Variable Sig = wcoef[8]
	Variable Res = 0.0001
	Make/O/N=(F1/Res-F0/Res,5)/FREE wFit
	SetScale/p x F0,Res,"",wFit
	wFit[][0] = 10^x
	wFit[][1] = Sig*(A0*t0/(1+(2*pi*10^x)^2*t0^2)+A1*t1/(1+(2*pi*10^x)^2*t1^2)+A2*t2/(1+(2*pi*10^x)^2*t2^2))/(A0*t0+A1*t1+A2*t2)
	wFit[][2] = 0
	wFit[][3] = -Sig*(A0*(2*pi*10^x)*t0^2/(1+(2*pi*10^x)^2*t0^2)+A1*(2*pi*10^x)*t1^2/(1+(2*pi*10^x)^2*t1^2)+A2*(2*pi*10^x)*t2^2/(1+(2*pi*10^x)^2*t2^2))/(A0*t0+A1*t1+A2*t2)
	wFit[][4] = 0
	Duplicate/O/FREE/R=[][0] wFit, SimFreqs
	Duplicate/O/FREE/R=[][1] wFit, SimX
	Duplicate/O/FREE/R=[][3] wFit, SimY
	yw[] = cmplx(interp(xw[p],SimFreqs,SimX),interp(xw[p],SimFreqs,SimY))
johnweeks
I think the combination of complex Y and real X should work. Could you post an experiment file? Complex fitting is pretty new and hardly used by anyone, so it hasn't had problems shaken out yet.
