CED-1401 AD board XOP
Hey,
I'm trying to usemafPC to control the CED-1401 AD board in IgorPro 6.37, but it's failed. Does anyone know of a working Igor plug-in (XOP) to interact with the CED interface?
Illegal AD device
chozo
I doubt you will get a satisfying answer, but I try my best to give some hints. You seem to be using a third-party or even user-written interface for this AD converter. It is unclear which board you are using (the original 1401?). Also, Igor 6.37 is ancient, but I assume the particular plugin you are using is still 32 bit which will not help you at all in modern Igor versions. The screenshot you posted does seem like something is not set up correctly and you just need to adjust the settings somewhere. Otherwise I am afraid that you will be out of luck.
erwinliu
Thank you, chozo.
I'm trying to configure the mafPC XOP which I used before. However, the CED Power1401 mk II data acquisition interface couldn't be called by mafPC directly. Dr. Xu-Friedman, the author of mafPC suggested me to find an IgorPro XOP to interact with the CED interface first.
