Need help modifying my axes
Hi folks,
I am having difficulties figuring out how to make the minimum point of my y-axis "not float". As you can see in the attached jpeg, currently the 0 and its tick are off-set from the bottom of the y-axis of the graph even though it is set as the minimum point. I want to remove this off-set. Pretty sure there is a simple fix for this but I can't seem to find what I am looking for in the manual.
Any help provided would be deeply appreciated.
Double click the axis. Then, in the Modify Axis dialog box, under the Axis tab in the column Axis, there is a check box for standoff. Uncheck to make 0 flush with the intersecting axis.
December 29, 2025 at 08:04 am - Permalink
Note that after you have unchecked Standoff for axes you can also save this behavior for all future graphs you create. Got to Graph => Capture Graph Prefs. In the panel select XY Plots: Axes and Axis Labels and then press Capture Prefs.
December 30, 2025 at 06:52 am - Permalink
