Duplicate variables (or strings) from one data folder to another
I want to duplicate a set of variables created at root: into a DataFolder existing at the root level. I came up with the code below (IP9). The two calls to SetDataFolder root: are safety redundancies.
string theItem, theSItem
SetDataFolder root:
wave/T varList = ListtoTextWave(VariableList("tau*",";",4) + VariableList("UB*",";",4),";")
SetDataFolder root:dataStore
for(theItem : varList)
	theSItem = "root:" + theItem
	NVAR tv = $theSItem
	variable/G $theItem = tv
SetDataFolder root:
Essentially, I have to a) collect the variable list at root, b) move to the storage data folder, c) iterate over the variable list to ci) reference the root: variable using NVAR and cii) generate the new variable using variable/G.
Does a more elegant way exist to duplicate variables (and strings)?
jjweimer
Just curious. How is it possible to "group them in a data folder" (programmatically) without something akin to the above?
In the meantime, I'm refactoring to store strings and variables in a root-level data folder at the outset (followed by DuplicateDataFolder).
And in the meantime, I would have wished to have raised my hand last year or so with IP10 for DuplicateVariable and DuplicateString commands (or Move.../D flag for "duplicate" rather than just move).
aclight
This code is arguably slightly cleaner:
Function DuplicateVars()
	DFREF rootDFR = root:
	DFREF dsDFR = root:dataStore:
	DFREF originalDFR = GetDataFolderDFR()
	SetDataFolder rootDFR
	SetDataFolder originalDFR
		NVAR/SDFR=rootDFR tv = $theItem
		variable/G dsDFR:$theItem = tv
Function makeStuff()
	Variable/G root:tau0 = 0
	Variable/G root:tau1 = 1
	Variable/G root:tau2 = 2
	Variable/G root:UB0 = 0
	Variable/G root:UB1 = 1
	Variable/G root:UB2 = 2
	NewDataFolder root:dataStore
I don't see how a DuplicateVariable or DuplicateString command would make this easier.
jjweimer
I see how the approach is somewhat cleaner. Is the DRFER line supposed to have an ending colon?
I was also hoping for a one line "duplicate" approach, essentially to avoid needing to use NVAR/SDFR. Perhaps akin to one of the following:
variable/G $theNewVarPath = $theOldVarPath
variable/G dsDFR:tv = rootDFR:tv
