X Axis points in the edit all waves table
I have recently upgraded from Igor 8 to Igor 10. In Igor 8, if I were to plot waves in a graph and then right click -> edit all waves, the resultant table only tabulated the Y-wave data, which was useful for me to manipulate data. In Igor 10, when I repeat the same process, each alternate column in the table now has the X-axis data. Is there a way to disable this?
kris
Hi Cameron,
I've tried to reproduce what you are seeing in Igor 8, but I see both X and Y waves in the Edit All Waves table in both Igor 8 and Igor 10.
Can you please email support@wavemetrics.com and send your Igor 8 experiment so I can try it out? You might also try turning off preferences in Igor 8 and see if that gives you the Igor 10 behavior that you are seeing. Misc > Preferences Off. If so, then that would give us an idea of what you can try in 10 to get the behavior you are looking for.
Kris
