secs2date format
I thought this format returned the date format without any separators  ... but it doesn't
textDate = secs2date(DT,-2,"")					// "YYYYMMDD"
What is the correct format for secs2date to obtain this format YYYYMMDD?
johnweeks
What you assume is quite reasonable- it should work that way. Looking at the source code shows that fixing it is surprisingly complicated, as the underlying code is used in a number of places, and we would have to be careful to make sure those other uses didn't break. I have entered a ticket for the change.
KZarzana
Edit: See John's comment above.
This will work:
textdate=ReplaceString("-", secs2date(DT,-2), "")
The Help says that if the separate str is omitted, then it defaults to "-", so my guess is that it's treating an empty string the same as an omitted string.  Perhaps one of the WaveMetrics folks can chime in.
