Igor Pro 10.05 Released
We're pleased to announce that Igor Pro 10.05 has been released. In addition to Igor Pro 10.05, we have also released version 1.0.1 of the Igor Pro MCP Server, which allows large language models (LLMs) such as Claude, GPT, and Gemini to communicate with and take action in Igor. Using the MCP Server requires Igor 10.05 or later. See the full documentation on installing and using the Igor Pro MCP server.
For more information, see the release announcement at https://www.wavemetrics.com/news/igor-pro-1005-released or What's Changed Since Igor Pro 10.00? | Igor Pro
forrest.r.blackburn
Has anyone started using IP 10.05 and successfully used it with Copilot? We are a MS house and for now, are using Copilot.
If you have, what has been your experience?
Also, if you are in a corporate environment, how easily has this version gone through your IT approval process? I’m concerned that because Copilot isn’t listed, that IT may not allow this version. And if that’s the case, will I be cut off from future versions of Igor Pro because my company doesn’t support using other AI assistants? Meaning, can we Turn OFF the AI assistant?
Ben Murphy-Baum
Forest, we’ve primarily been using github copilot for testing the MCP server, and it’s worked very well for us. The AI assistant is run external to Igor in whatever application you prefer that supports MCP tools. So I’m usually using VS Code with my GitHub copilot subscription. The MCP server is the connector between VS Code’s AI chat and Igor. It’s completely optional, Igor has settings to block these connections, and is a separate installed product to Igor itself.
KB
I have had success using IP 10.05 with GitHub Copilot Desktop, which is their new desktop app. I am not sure if that is the same Copilot app you are using though.
