Igor mcp experience
Igor 10.05 includes mcp server for AI agents, and with lot more functionality than I would have expected. Congratulations to WM.
Here are some, hopefully useful, observations.
Setup : complicated by my macOS platform left behind by WM. Surprisingly, there is working solution how to get macOS AI harness talking with Windows version of Igor 10 through Windows mcp.  My AI agents are running on macOS in my private harness application Aida-workbench (https://github.com/jilavsky/aida) and I have Igor 10.05 running on my M5 MBP using CrossOver. Turns out, you can configure macOS to start and talk to windows application running in CrossOver, in this case igor-mcp-server.exe, which then talks to Igor Pro 10.05 running in the same "bottle". I was pleasantly surprised. I had ChatGPT write me how to configure the mcp.json file for this weird case. If anyone needs that, I can paste it here later. It is surprisingly easy.
Test: Trivial test... ask AI agent to generate plot of sin(x) for x=0 to 2pi.
Results: works perfectly fine. Got perfect Igor graph in Igor application, my Aida got image as png file and showed it to me, so it can be used in any output agent is making.
Agent capabilities are important :
  • Cloud model (tested with Claude Sonnet 5.5) seem to know well enough what to do in Igor and handles Igor programming/control without mistakes (at least big ones).
  • Local model (relatively capable and new - Inkling-2-mini) make few syntax errors and had to search through help/manuals. Eventually achieved what was asked.
Local model improved after providing Igor-pro skills as documentation (start set is here: https://github.com/jilavsky/igorpro-skills). I suspect a good skills documentation will be critical to make AI agents operate Igor efficiently with these new capabilities. Large Cloud models seem smart enough to use Igor already, but if anyone needs to use smaller local models, they will need way to teach them how to do it efficiently.
Either way, this was easier and better than I expected. Once more, congratulations to WM.
Ben Murphy-Baum
Thanks for the feedback, I'm glad it's working well for you even on your crossover setup! Admittedly, we haven't tested how well local models perform in tandem with the mcp server, so it's encouraging that Inkling-2-mini was able to work out with a little help. I imagine the situation will only improve as time goes on.
ilavsky
Bit more testing...
I fetched the whole on-line Igor 10 manual from WM web site (https://docs.wavemetrics.com) as md documents (THANKS WM, very helpful) and created skills folder which contains command references for all Igor commands. Well, Claude created it.
With these skills even local agent seems to be able to get syntax reasonably well and make less mistakes. It's the "mcp skills/igor-pro" folder here: https://github.com/jilavsky/igorpro-skills.
This may be useful even for cloud models (Claude etc) since Claude Opus 5.5 confirmed, that its own memory is bit hazy on Igor 10 syntax and differences between Igor versions. Training cut off dates and pollution of memory by old manuals and old code examples is challenge.
For anyone trying to use local agents (due to cost or due to privacy requirements) - you need beefy recent models. Small models have real challenge using mcp tools properly and make mistakes. My experience is that 30B dense models (Muse-Glimer, Qwen 3.8) work quite well (but are slower). The recent Inkling-2-mini (which is MOE) seems good enough. Unluckily, all of those need really good hardware. But this will likely change in few weeks/months.
aclight
Jan, are you running those local models on your own hardware, or does your institution have a way for you to use them on servers they run? If you're running on your own hardware, I'm curious what that hardware is.
There was a plan to ship all .md documentation with Igor so the MCP server's get_help tool could read that documentation locally, instead of grabbing it from docs.wavemetrics.com each time. However that wasn't something I had time to finish before I left.
ilavsky
Hello Adam,
I was lucky to buy M5MAX 64GB RAM MBP in August before the cost skyrocketed - and even that was nearly $5k I think (as work computer, not filthy rich myself). It is beast and can run relatively reasonable models with 100+ tok/sec at 260k - 1M context. They are quite usable. Cost nothing to run (well, 100W power input). I am getting real work done with them, mostly for fun at home over weekend, since we also have cloud models available at work with generous token/month budget (lucky me!). I tried both, Claude Opus 5.5 handles Igor quite easily.
I have done part of what you planned with md files for agents in my https://github.com/jilavsky/igorpro-skills - there is command reference and other parts of manual there, took Claude few minutes to distill from downloaded manual WM server provided generously.
Since I make my stuff as permissive as I can (AI told me to use MIT license), anyone can do anything with it. I would be happy in WM would used it with the mcp, it would be useful for all. And, may be, my Claude missed something which needs to be fixed, expert check would be useful.
BTW: I have realized that my Irena/Nika/Indra packages need serious work, if they should be used through mcp by agents. Even Opus or Fable... Skills for those are critically needed, but still - apparently mcp breaks on DoAlert and other popup dialogs which my packages are full of. I now need to wrap 400 or so places in some recovery code which will prevent need for user to click "OK" for agent ;-) It was kind of fun: agent testing stuff and asking, again and again, "can you click OK on the dialog"...
Looks like a feature is missing from mcp...
Well, great to hear from you and really sorry you left Adam. The best in the future.
Jan
aclight
If you start Igor with the /UNATTENDED command line flag, some modal dialogs (e.g. compile error dialogs) are skipped. The MCP server has an option to use this flag with the tool that starts Igor. However I decided that since the purpose of DoAlert was to alert the user, that dialog shouldn't be skipped with the /UNATTENDED flag.
My guess is that you can just ask Claude to fix your package to add a route that skips the DoAlert. Then you can ask it to find any bugs in your code and it'll find a lot.
With that said, Claude is smart enough to figure out how to send key presses (enter and/or escape) to dismiss dialogs such as that. I think the tricky thing is that the mcp server will need to monitor Igor's state to see if an alert is up, and if so to do something. I think that if you explain the problem to Claude (or possibly just show it my comment here) you can get it to figure out what it needs to do.
Regarding your skills, I don't know how necessary they are. I used the MCP server through GitHub Copilot with Claude Opus (and to some extent Sonnet) without any skills and generally speaking it was able to build what I wanted it to build without further input from me. Perhaps some of that is due to memories it had written in the past that helped with some of Igor's surprising syntax. I can believe that skills could make certain tasks finish faster and/or with fewer tokens, so I'm not saying there is no benefit to them.
Thanks for the details on what hardware you are using. I don't yet have the desire to buy something from Apple (nor the $5k) and at $100/month for a Claude Max subscription it's been hard for me to see the value in purchasing the expensive hardware to run a local model that's not as good as Claude. Maybe that won't be the case for all that long with the way things are changing.
