FuncFit Error Flag?
**** Singular matrix error during curve fitting ****
which I know means that the equation has too many parameters and one is ill defined. (I'm fitting single exponentials versus double exponentials).
Unfortunately, this singular matrix error crashes my whole macro, when what I'd really like it to do is to generate an error message (that I can redirect somewhere), and continue with the next fit in the macro. It seems like there should be a flag whose status I can check before the macro crashes so that I can skip over the crash part.
Is this making sense?
-Karen f.
This might need to be done from a function instead of a macro, but I think it should also work from a macro.
June 2, 2008 at 11:23 am - Permalink
Thank you, Adam.
Karen, you may also want the V_fitOptions variable:
Variable V_fitOptions=4
... the loop that does the fitting ...
This will suppress the curve fit progress window that keeps flashing. It will substantially speed up the loop. If you really have written a macro instead of a function, you may find that making it a function speeds things up quite a bit.
June 3, 2008 at 01:03 pm - Permalink
November 5, 2008 at 09:03 am - Permalink
V_FitError works for a macro, but a loop in a macro is very slow. You're better off writing a function.
November 7, 2008 at 11:20 am - Permalink
