Customize tables properties
Is it possible to customize the look of a table (e.g. remove the column where are written the rows numbers) ?
Moreover, I'd like to write-protect the table (i.e. display a read-only table).
Thanks in advance
Regards
awirsing
Nasser wrote: Is it possible to customize the look of a table (e.g. remove the column where are written the rows numbers)?
You are looking for the modifyTable command together with the showParts keyword.
To hide the point column use
modifytable showparts=255 & ~(2^3)
To hide also the entry field (this makes the table read-only) and make the selection highlighting invisible use
modifytable showparts=255 & ~(2^0+2^3+2^6)
To find out more read the section about the ModifyTable command in the documentation.
A
