listbox problem
awirsing
Thu, 04/02/2009 - 07:12 am
The problem is: When I set a cursor an a trace of the graph, I can't move this cursor by the keyboard arrow keys, also CMD-A for SetAxis/A does not work any longer. It seems that all keyboard strokes are intercepted by the listbox action procedure. I tried setting the active subwindow to the host window of the listbox panel, but without success.
Any hints are much appreciated.
I am using IP 6.10B06 on a MB Pro.
I could not reproduce this exactly, but noticed something curious that may be related.
Using the "default" ListBox Action Procedure (obtained by clicking on the "new" button in the dialog that opens when you double-click on an existing listbox control), my IP6.10B06 (Win) responded to keyboard strokes (at least to the arrow keys). This however relied on the graph window being the active subwindow (achieved by clicking on it). I let Igor figure out how to set the active subwindow properly, i.e. I looked at the Graph0 recreation macro generated by Igor.
I noticed something funny: Even with the active subwindow set up with the command
SetActiveSubwindow ##
, the cursor was redrawn in the exterior panel. I had to add aShowInfo;HideInfo
sequence to prevent this. You can find these two behaviors in the snippet below. Paste this into your Procedure window and choose "start1" or "start2" from the Macros menu.Cheers,
Wolfgang Harneit
Macro Start1()
make/O w={1,2,4,5}
display w
Cursor A w 1
Make/T/O tw={"abc","def"}
Graph1()
Macro Start2()
make/O w={1,2,4,5}
display w
Cursor A w 1
Graph2()
Function ListBoxProc(lba) : ListBoxControl
STRUCT WMListboxAction &lba
Window Graph1() : Graph
PauseUpdate; Silent 1 // building window...
Display /W=(35.25,42.5,429.75,251) w
Cursor/P A w 0
NewPanel/HOST=#/EXT=0/W=(0,0,217,278)
ListBox list0,pos={1,2},size={150,103},proc=ListBoxProc,listWave=root:tw
RenameWindow #,P0
ShowInfo
HideInfo
EndMacro
Window Graph2() : Graph
Cursor/P A w 0
RenameWindow #,P0
// ShowInfo
// HideInfo
EndMacro
April 2, 2009 at 11:21 am - Permalink
To illustrate the problem paste my snippet in the procedure window and choose Start3 from the macro menu.
I couldn't find a way to move the cursor by means of the keyboard's arrow keys. Hitting these keys invokes the listbox action procedure once you clicked in the listbox as you can see by the prints in the history although the active subwindow is set to the host window.
make/O w1={1,2,4,5}
make/O w2={5,4,2,3}
Make/T/O tw={"w1","w2"}
Graph3()
Window Graph3() : Graph
Display /W=(155,82,550,290) w1
Cursor/P A w1 0
NewPanel/HOST=#/EXT=1/W=(0,0,15,100)/K=2
ListBox list0,pos={1,2},size={150,103},mode=1,selrow=-1,proc=ListBoxProc3,listWave=tw
RenameWindow #,P0
ShowInfo
EndMacro
Function ListBoxProc3(lba) : ListBoxControl
Variable row = lba.row
WAVE/T/Z listWave = lba.listWave
switch( lba.eventCode )
case 4: // cell selection
switch(row)
case 0:
print "case 0"
removefromgraph $removeending(tracenamelist("",",",1))
appendtograph $(listwave[0])
DoUpdate
cursor/p a $(listwave[0]) 1
break
case 1:
print "case 1"
appendtograph $(listwave[1])
DoUpdate
cursor/p a $(listwave[1]) 2
break
endswitch
break
endswitch
@ Wolfgang: Also your Showinfo;Hideinfo trick doesn't aktually solve the problem. Once you click on the listbox moving the cursor with the arrow keys is disabled. This applies to both cases (Start1 and Start2).
April 2, 2009 at 02:50 pm - Permalink
Details: in order to get the keyboard focus off the listbox control, I just put a dummy button somewhere in your panel where it can't be seen (some dirty trick). That was the "easy" part - the cursor immediately starts to respond. But the listbox is then definitely not responding to keyboard strokes anymore. So I tried to remedy that by introducing a window hook for the graph window that catches the keyboard strokes. Also quite easy. But then I had to come up with an update mechanism and I wanted to keep the listbox control synchronized with the updates. That was quite hard, and may be the fragile part. Please test & comment.
Wolfgang Harneit
make/O w1={1,2,4,5}
make/O w2={5,4,2,3}
Variable/G root:recentlyDisplayedWave = 0
Make/O/N=(numpnts(tw)) cursorPositions=0
Graph3()
Cursor/P A w1 0
ListBox list0,pos={1,2},size={150,103},mode=1,selrow=0,proc=ListBoxProc3,listWave=tw
RenameWindow #,P0
ShowInfo
SetWindow Graph3, hook(myhook)=GraphWinHook
EndMacro
NVAR oldRow = root:recentlyDisplayedWave
if( oldRow != row )
SwapWaves(oldRow, row, listWave)
oldRow = row
break
endswitch
function SwapWaves(oldRow, newRow, listWave)
variable oldRow, newRow
Wave/T listWave
WAVE cursorPos = root:cursorPositions
cursorPos[oldRow] = pcsr(A)
RemoveFromGraph/W=Graph3 $(listWave[oldRow])
AppendToGraph/W=Graph3 $(listWave[newRow])
Cursor/p a $(listWave[newRow]) cursorPos[newRow]
Button dummy,pos={200,200},win=Graph3#P0 // makes listbox control lose keyboard focus
DoUpdate
function GraphWinHook(whs)
struct WMWinHookStruct &whs
if( whs.eventCode == 11 && (whs.keycode == 30 || whs.keycode == 31) )
ControlInfo/W=Graph3#P0 list0
wave/T listWave = $S_value
variable oldRow = V_Value, newRow
if( whs.keycode == 30 ) // cursor up
newRow = max(0, oldRow - 1)
else // cursor down
newRow = min(numpnts(listWave) - 1, oldRow + 1)
ListBox list0, selRow= newRow, win= Graph3#P0
April 2, 2009 at 08:39 pm - Permalink
For my purpose I established another quick and dirty solution: Clicking the listbox kills the external panel and I put a button on the host panel which invokes the external panel (and the listbox) again. I have anyway a lot of buttons on the host panel, so one more doesn't hurt. Thanks again, Wolfgang, for your effort.
April 3, 2009 at 12:52 am - Permalink
I will put this on my list of things to look into.
April 6, 2009 at 11:29 am - Permalink
Are there any news on this issue?
I'm using Igor 6.21 on Windows XP SP3.
March 11, 2011 at 03:01 am - Permalink
There are.
I had an off-list discussion with John several months ago. He suggested to disable the listbox temporarily:
ListBox theList,win=pathToThe#ExtWin,disable=0
This worked for me very nicely and replaced my 100-line workaround by just 2 lines.
A
March 14, 2011 at 01:40 pm - Permalink
March 14, 2011 at 12:32 pm - Permalink
