Set shortcuts
Hi all,
Is there a way to set shortcuts to some functions one needs to run all the time? instead of writing it in the command line window or clicking a button on some panel -- just to type a user defined shortcut from the keyboard ...
Thank you !
You can create user defined menus that have shortcut keys, and when the menu item is invoked it can call an Igor function or a user macro or function.
Execute the following command in Igor's command window to get more information:
DisplayHelpTopic "User-Defined Menus"
I understand that this may be achieved using user-defined menus. But can I simply use Mac OS 10.6 System Preferences > Keyboard shortcuts to assign a shortcut to an existing menu item? I tried to assign Ctrl+A to "Add Annotation...". Then "^A" successfully appeared beside it, but it did not take effect when I pressed Ctrl+A.
isend wrote: I understand that this may be achieved using user-defined menus. But can I simply use Mac OS 10.6 System Preferences > Keyboard shortcuts to assign a shortcut to an existing menu item? I tried to assign Ctrl+A to "Add Annotation...". Then "^A" successfully appeared beside it, but it did not take effect when I pressed Ctrl+A.
I think this conflicts with Igor's special keyboard handling for graphs. When a graph window is active and you type, Igor assumes that you want to type a command and switches focus to the Command Window. That disables the Graph menu. Evidently, we don't check adequately for special keys when we do this.
Thank you John. Your response gave me some insight and I then realized that I could use the "command" key instead. I successfully assign "command + x" for Add Annotation.
isend wrote: Thank you John. Your response gave me some insight and I then realized that I could use the "command" key instead. I successfully assign "command + x" for Add Annotation.
OK. Of course, that conflicts with Edit->Cut. We reserve function keys and Cmd-number for users; I think we have used up pretty much all the unmodified letter keys. Perhaps try Cmd-Option-somekey or Cmd-Control-somekey.
