Replacement of separation values / Save routine
Hello Everybody,
I have a simple question, which actually bothers me a little bit. :-)
I am using IGOR since a long time (>7y), but this simple problem I did not get fixed.
I would like to import a tab-separated text file and just want to replace the separation charcter from tab to a semicolon. In the LoadWave routine I can choose the separator...in the Save routine its not possible (I think).
This replacement will be done automatically (called from Windows) and is needed to fulfill the actual program. I hope somebody has a smooth and easy idea to perform this. Anything is ready...I just need this easy part performed by IGOR ;-)
Many thanks and best wishes
Raik
jtigor
Raik,
Try the following code. It worked for my simple test. There is probably a better solution out there.
Jeff
Function ReplaceCharacter()
	String sLine
	String sMsg = "Select file to convert"
	String sOutputFile
	String sInputFile
	String sIdentifier = "_Converted"
	String sFileExtension
	String sFileName
	String sFilePath
	Variable vFileRef_Old		//input file handle
	Variable vFileRef_New		//output file handle
	Open /D /M=sMsg /R  vFileRef	//just getting info on file to open here, not actually opening yet
	if(strlen(S_fileName) == 0)
		return 0	//user canceled
	sInputFile = ParseFilePath(5, S_fileName, ":", 0, 0)		//convert path to mac style
	sFileExtension = ParseFilePath(4, sInputFile, ":", 0, 0)	//file extension
	sFilePath = ParseFilePath(1, sInputFile, ":", 1, 0)			//path without filename
	sFileName = ParseFilePath(3, sInputFile, ":", 0, 0)		//filename without extension
	sOutputFile = sFilePath + sFileName + sIdentifier + "." + sFileExtension	//destination file name + path
	Open /R  vFileRef_Old as sInputFile		//open the source ile for read only
	Open  vFileRef_New as sOutputFile		//create new destination file for output
	Do
		FReadLine vFileRef_Old, sLine //read one line terminated by CR, LF, CRLF or LFCR
		if(strlen(sLine) == 0)
			break	//end of file reached
		sLine = ReplaceString("\t", sLine, ";")	//replace tabs with semicolons
		fprintf vFileRef_New,"%s\r\n",  sLine		//write modified line to new file
	While(1)
	Close vFileRef_Old		//close source file
	Close vFileRef_New		//close destination file
