One question about multithread and fitting with implicit function
... ThreadSafe Function Func_Ellipse(Coefs, x, y) : FitFunc Wave Coefs // Coefs[0] = theta, Coefs[1] = x_0, Coefs[2] = y_0, Coefs[3] = a, Coefs[4] = b, Variable x, y Return ((x - Coefs[1]) / Coefs[3]) ^ 2 + ((y - Coefs[2]) / Coefs[4]) ^2 + cos(Coefs[0]) ^ 2 - 2 * cos(Coefs[0]) * (x - Coefs[1]) * (y - Coefs[2]) / (Coefs[3] * Coefs[4]) - 1 End Function Fit_ellipse(Data_x, Data_y, Coefs_ellipse, Data_fitted_x, Data_fitted_y) Wave Data_x, Data_y, Coefs_ellipse, Data_fitted_x, Data_fitted_y Variable V_fitOptions=4 FuncFit /N=1 /NTHR=1 /ODR=3 /Q=1 /W=2 Func_Ellipse, Coefs_ellipse /X={Data_x, Data_y} /XD={Data_fitted_x, Data_fitted_y} End ...
I found no matter how I set /NTHR=0, 1 or 2, the activity monitor showed 2 cpu cores were mostly occupied. It seemed to me that the multithread was always on but the computation time was quite different for /NTHR=1. If /NTHR=0 or 2, the computation time was more than twice for /NTHR=1. The data points for the fitting was about 25,000. Is there any reason for the phenomenon I observed?
If, in fact, you are using the Multithread keyword in your fitting function, then you should use /NTHR=1. It is a bad idea to use threading inside something that is already threaded. Using /NTHR=0 will cause a normal user-defined fit function to use as many threads as the number of processors available. If you use Multithread inside such a function, then you are using more threads than processors available, and the result is very likely to be a degradation in performance.
The Multithread keyword was added after the threading support for user-defined functions. I should re-visit some of my code, and the documentation to address some of these issues of when it is appropriate to use threading.
May 12, 2011 at 09:37 am - Permalink
I did not use the keyword "MultiThread" in my fitting function. The function used is just as shown here. That is also why I post here to ask. I did not set MultiThread keyword in my function and only set /NTHR=1 but two cores were mostly fully occupied. Meanwhile, I am confused as well why the result of /NTHR=0 is worse than /NTHR=1.
I am also wondering how I should do write my implicit fitting function in the form of All-at-once?
May 12, 2011 at 10:20 am - Permalink
May 13, 2011 at 09:41 am - Permalink
