plotting multi figures in the same interface with different panel
Hi all,
I have a simple question about plotting two or more figures in the same interface with different panels, such as two panels: up and down, or left and right.
Thanks so much in advance.
jjweimer
I suspect that you are wanting either to create a stacked/tiled graph of curves or to lay out plots in a stacked/tiled arrangement on a page. For the former, see page II-292 of the manual. For the latter, see Chapter II-16 of the manual.
Perhaps you could then otherwise provide further details of your question so we can help.
hrodstein
urion wrote: I have a simple question about plotting two or more figures in the same interface with different panels, such as two panels: up and down, or left and right.
You can put multiple plots on one graph using free axes. For example:
Function DemoSideBySidePlots()
	Make/O jack=sin(x/8), joe=cos(x/8)
	// Display jack versus left and bottom axes
	Display /W=(35,44,430,252) jack
	// Limit length of bottom axis
	ModifyGraph axisEnab(bottom)={0,0.4}
	// Other tweaks for left and bottom
	ModifyGraph standoff(left)=0,standoff(bottom)=0
	ModifyGraph lblPos(left)=60,lblPos(bottom)=39
	// Display joe versus left2 and bottom2 free axes
	AppendToGraph/L=left2/B=bottom2 joe
	// Limit length of bottom2 axis
	ModifyGraph axisEnab(bottom2)={0.6,1}
	// Other tweaks for left2 and bottom2
	ModifyGraph freePos(left2)={0.6,kwFraction}
	ModifyGraph freePos(bottom2)={0,kwFraction}
To learn about this, execute:
DisplayHelpTopic "Types of Axes"
DisplayHelpTopic "Creating Graphs with Multiple Axes"
You can also embed graph subwindows in other windows:
DisplayHelpTopic "Embedding and Subwindows"
For presentation purposes I would tend to use free axes. For user-interfaces I would tend to use subwindows.
