Exporting Graphics Via the Clipboard
I want to export a graphic from the active graph via the clipboard, and I choose Edit→Export Graphics. This displays the Export Graphics dialog. But from the Format pop-up menu, I can only choose Enhanced Metafile, Bitmap, PDF, PNG Image, and TIFF Image, but actually I want to choose PostScript Enhanced Metafile. I find there is a item of PostScript Enhanced Metafile on another computer. What make the difference of the two computer?
Any suggestions are appreciated.
Thanks.
WTZero
August 30, 2011 at 05:52 pm - Permalink
I want to export a graphic from the active graph via the clipboard, and I choose Edit→Export Graphics. This displays the Export Graphics dialog. But from the Format pop-up menu, I can only choose Enhanced Metafile, Bitmap, PDF, PNG Image, and TIFF Image, but actually I want to choose PostScript Enhanced Metafile. I find there is a item of PostScript Enhanced Metafile on another computer. What make the difference of the two computer?[/quote]
That other computer must be a Macintosh, not a PC like yours. I think if you use an Enhanced metafile you should get pretty good results.
August 30, 2011 at 08:56 pm - Permalink
Software Engineer, WaveMetrics, Inc.[/quote]
Actually, the other computer is PC with windows XP installed. I don't know what make the difference that my computer is windows 7.
Wentao
August 31, 2011 at 01:28 pm - Permalink
To get PostScript quality, activate your graph and choose File->Save Graphics. Choose PDF if the program you are exporting to supports it or EPS.
EPS is not supported by other programs as a clipboard format so you have to export to a file, not to the clipboard.
PDF is supported as a clipboard format on Macintosh but is not supported by other programs on Windows so on Windows you have to export to a file, not to the clipboard.
September 1, 2011 at 07:49 am - Permalink
