Reading headers in matrix data loading
I am having trouble reading header info from some Atomic Force Microscopy images. The data are opened in "Gwyddion" where I convert the images to txt files including some header information which relate to the x and y scales of the image. I have written a procedure for opening and presenting these image files but this has required manually entering the x/y scale for the SetScale operation. I would like to be able to use the header information during the data load to set the scale automatically. The data is of the form:
# Channel: Height
# Width: 2.000 µm
# Height: 2.000 µm
# Value units: m
1.02e-007 1.04e-007 1.02e-007..... matrix data
I obviously then need to be able to read out the header info for height and width. I have looked at the FReadLine operation and the Load File Demo experiment but can't figure out how to read only those points (e.g. Line 2, col 10 - 14 & line 3, col 10 - 14). Would it also be possible to get the units this way? i.e. here it says 2.000 µm but some images are on the nanometer scale so would need to be scaled accordingly.
Many thanks.
This will only work if the character positions are fixed and don't vary from file to file.
If their positions in the string do vary, then try using strsearch to find the ":" as a marker. Pull out the last two characters as the units string and the remainder is the numeric portion.
October 4, 2011 at 06:13 am - Permalink
To only read the second line just call FReadLine twice, throwing away the first result.
Also, for that kind of parsing my first choice is usually
sscanf. Alternatively you could considerSplitStringbut I prefer to go with sscanf if I can.October 4, 2011 at 06:19 am - Permalink
If you are not familiar with Igor symbolic paths, execute this:
Also, the units in the example you sent use a micro character. Micro is coded differently on Windows and Macintosh so, after pasting the code below into a procedure window, make sure that the micro character (see comment in two places below) is in fact a micro character.
This solution is tailored to the text you posted exactly. If the actual file is any different you will need to adjust.
October 4, 2011 at 10:46 am - Permalink
October 6, 2011 at 06:37 am - Permalink
I believe this is because your data file uses UTF-8 text encoding. This is an encoding format of Unicode in which all of the original 128 ASCII characters are represented by themselves and all of the other Unicode characters are represented by 2-, 3- or 4-byte sequences.
Igor Pro 6 does not understand UTF-8 so the UTF-8 mu character appears in Igor (on Windows) as "µ".
Your solution to this issue is the correct one. But you might want to leave in the original case statement, giving two consecutive case statements, so that it will work if you happen to have a file that uses Windows Latin1 text encoding.
I suspect there is an extra byte in the text file. You would see it if you dumped it in hex. You should also see it if you open it as an Igor notebook. You won't see it if you open it in a UTF-8-aware program.
When you copy it to the clipboard, the system creates a "system text encoding" version of the text in which the micro is represented in Windows Latin1 text encoding as a single byte.
October 6, 2011 at 09:39 am - Permalink
