A custom fitting equation that also calls a fit
Hi everyone,
I have written a fitting function to do some complicated fitting for me. to calculate a y value for given parameters my fit function runs a simulation of a differential equation to find out how a variable changes with time, and then fits this response to an exponential to find out the decaying time scale. for this exp fit fit I use a custom coefficients wave so to not interfere with the coefficient wave of the main fit. I still see problems, mainly:
1) My main fit freezes after awhile (I have to ctrl-alt-delete to exit), and at this time I see that it begins to think there are three coefficients instead of two that I expect. I wonder if somehow the exp fitting (which has three fit parameters) that happens during the fit some how messes with the fit.
2) I see the fitting algorithm run the same parameters (or very close to the same) a couple times in a row before moving on to the next point, this seems strange and adds significant time to my fit, maybe this is normal?
I know igor uses a lot of other variables during a fit, maybe I need to somehow save the current values before running my exp fit and then reload the values back in? If this is the case are there particular values which are important?
Michael
johnweeks
The response is not correct, unfortunately. The response dealt with using FindRoots in a fitting function. Unfortunately, Igor's curve fitting operations are not written in a re-entrant way, so you can't use a curve fit inside a fit.
I recently added a check for recursion in the fitting code so that instead of crashing it would issue an error. What version of Igor are you using?
SailBlue5
I am using version 6.2.2.2, downloaded recently. It doesn't give any warning messages. I feared that this was the case.
Any work arounds I could do?
johnweeks
SailBlue5 wrote: I am using version 6.2.2.2, downloaded recently. It doesn't give any warning messages. I feared that this was the case.
Hm. I just checked our source code repository- I added that error message three years ago. Seems like just yesterday... You didn't show the code of your fit function, so it's hard to know what might be going wrong there. Possibly you need to use the special variable V_FitError. To read about it, execute this command:
DisplayHelpTopic "Special Variables for Curve Fitting"
Well, come to think of it, you might be able to do it by spawning a separate thread and doing your inner curve fit in that thread. Your inner fit function will have to be thread-safe. It's not the usual reason for threading (that would be speed, and since your outer fit requires the result from your inner thread, they can't run concurrently and won't save time). But a thread has its own environment, including global variables so it should solve the re-entrancy problem.
SailBlue5
#pragma rtGlobals=1	// Use modern global access method.
//This function works as a basic fit function for Diffusion's dependence on oscillating amplitude
Function DiffusionVsOscAmplitude(w,OscAmp) : FitFunc
	Wave w
	Variable OscAmp
	//CurveFitDialog/ Equation:
	//CurveFitDialog/ This runs a simulation to the differential equation determine the fit.
	//CurveFitDialog/ OscAmp
	//CurveFitDialog/ Coefficients 2
	//CurveFitDialog/ w[0] = Ds
	//CurveFitDialog/ w[1] = invtm
print "Starting fitfunc"
	//Set global variables
	variable /G position_cm = 200e-7
	variable /G SimLength_cm =400e-7
	Variable /G dx_cm = 2e-7
	variable /G dt_s = .0002
	variable /G SimTime_s = 3
	//Make the sensitive volume
	SenSliceFull(OscAmp)
	print OscAmp
	print w[0]
	print w[1]
print "Calling runSim"
	return RunSimulation(w[0],w[1])
//To run the simulation
Function RunSimulation(Ds, invtm)
	Variable Ds     //diffusion constant
	Variable invtm  //Relaxation rate for T_1 or \tau_m
print "In RunSim"
	Variable /G dx_cm
	variable /G dt_s
	Wave ExpFits
	Wave SenSlice
	Wave Spins
	variable Iterations = round(SimTime_s/dt_s) //Number of spatial points to simulate
	variable Positions = round(SimLength_cm/dx_cm)  //Number of time steps to take
	variable frac = cosh(dt_s*invtm)*exp(-1*dt_s*invtm)  //the fraction of spins that flip in time dt.
	variable i  //Will hold the time step
	variable j //will hold the position step
	variable k //used to update plots every now and then
	variable sum  //will hold the integration of Spin*SenSlice
	variable result  //The resultant measured inverse corrolation time of the force
	Make /O /N=(Positions) TempSpins  //This will hold the spin state at the next time step temporarly
	Make /O /N=(Iterations) OrigSpinState  //This will hold how much of the original spin state is left convolved with the sen slice vs time (for each dt)
	SetScale/P x 0,(dt_s),"", OrigSpinState  //each point repersents a single time step
	Make /O /N=2 TempCoef  //Since we will have a fit inside a fit we need to do house cleaning so the two W-coef waves do not screw with each other
	OrigSpinState = nan  //just so I don't have lingering values from a previous run
	for(i=0;i<Iterations;i=i+1)
		sum = 0
		for(j=0;j<Positions; j=j+1)
			sum = sum + SenSlice[j]*Spins[j]  //Integrate to find "force"
			//Spins diffusing
			if(j==0)
				TempSpins[j] = Spins[j] + Ds*dt_s*(Spins[j+1]-Spins[j])/(dx_cm*dx_cm)  	//spins are blocked from diffusing past on the left side
				//TempSpins[j] = 0													//Spins diffuse past the left side (and disapear)
			elseif(j==Positions-1)
				TempSpins[j] = Spins[j] + Ds*dt_s*(Spins[j-1]-Spins[j])/(dx_cm*dx_cm)  //spins are blocked from diffusing past on the right side
				//TempSpins[j] = 0													//Spins diffuse past the right side (and disapear)
				TempSpins[j] = Spins[j] + Ds*dt_s*(Spins[j-1]+Spins[j+1]-2*Spins[j])/(dx_cm*dx_cm)
		OrigSpinState[i] = sum  //The "force" at this time period
			Spins[j] = frac*TempSpins[j]  //Get ready for next iteration
		if(k<1)
			doUpdate
			k=Iterations/100
		k=k-1
	print "Calling fit"
	CurveFit/NTHR=0 exp kwCWave=ExpFits,  OrigSpinState /D
	print ExpFits[2]
	print "Returning"
	return ExpFits[2]
Function SenSliceFull(OscAmp)
	variable OscAmp
	Variable /G dx_cm
	variable i
	Make /O /N=(round(SimLength_cm/dx_cm)) SenSlice
	Make /O /N=(round(SimLength_cm/dx_cm)) Spins
	for(i=0;i<round(SimLength_cm/dx_cm);i=i+1)
		SenSlice[i]=0
		Spins[i]=0
	for(i=ceil(-1*(OscAmp/dx_cm));i<=floor(OscAmp/dx_cm);i=i+1)
		SenSlice[round(position_cm/dx_cm)+i]=Cos((i*dx_cm/OscAmp)*(pi/2))
		Spins[round(position_cm/dx_cm)+i]=1
	SetScale/P x 0,(dx_cm),"", SenSlice
	SetScale/P x 0,(dx_cm),"", Spins
There is my code. The fit is being done in the function run simulation right before the return. I'll look in to threading and the special variable. Thanks.
Michael
johnweeks
Michael-
Here is some code that might serve as a start on trying my idea. To read about threading, and what the calls in this code do, execute this command:
DisplayHelpTopic "ThreadSafe Functions and Multitasking"
Note that my code is not complete, so I haven't tested it. But it should serve as a starting point. I will be very interested to know if this works!
threadsafe Function DoMyFit(cwave, datawave)
	Wave cwave, datawave
	CurveFit/NTHR=1 exp kwCWave=cwave,  datawave
Function runsimulation(Ds, invtm)
	//*** lots of code here****
	Variable threadid = ThreadGroupCreate(1)		// just one thread to encapsulate the inner fit
	ThreadStart threadid, 0, DoMyFit(ExpFits,  OrigSpinState)
	do
		variable tgs= ThreadGroupWait(threadid,5000)		// five-second wait is excessive, but we don't want to spin the loop.
												// We just want to wait until the inner fit is done, which could be fairly lengthy.
	while( tgs != 0 )
	return ExpFits[2]
SailBlue5
johnweeks wrote: Michael-
	do
	while( tgs != 0 )
	return ExpFits[2]
Creating a new thread worked. I was able to perform the fitting function within a fitting function.
johnweeks
SailBlue5 wrote: Creating a new thread worked. I was able to perform the fitting function within a fitting function.
Excellent! Thanks for letting me know. There may be others that could benefit from this.
