Gauss2D Fit: 'cor' parameter
I'm using the Gauss2D function to fit data contained in an image.
In this function, we have the possibility to access to a 'cor' parameter, which corresponds to a cross-correlation parameter.
What does it represent exactly. I can't find this formula on the litterature.
The second question is maybe a lack of knowledge but if in my image I've got something like a PSF that looks like an ellipse. If I want to fit this PSF with a function that could reveal the fact that the ellipse could be rotated compared to the axes, how could I do?
Thanks for your help.
Sébastien
johnweeks
mailfert wrote: I'm using the Gauss2D function to fit data contained in an image.
http://en.wikipedia.org/wiki/Multivariate_normal_distribution
But note that Igor fits a function that is not normalized as a probability distribution (that is, the total integral is not equal to 1.0).
I assume that you mean that the projection of the PSF onto the XY plane has an elliptical outline, and the distribution of Z values is Gaussian. The ellipse at an angle is what the cor fit coefficient is for. If you are looking for a fitting function that uses the angle with the X axis as a fit parameter, you will need to find the formula and create a user-defined fitting function.
s.r.chinn
Here is an example function that may help you. I have simplified the image to have no baseline or average x, y offsets. These can be added with suitable modification of the user-defined fit function. You may also want to add to the function a way to refine the w_coef initial guesses.
function Ellipse(theta)
	variable theta		//	rotation angle -  radians
	Make/O/N=(100,100) w2D	//	make a test wave for the input angle
	setscale x, -4, 4, "" w2D
	setscale y, -4, 4, "" w2D
	variable sigmax	=	1
	variable sigmay	=	2
	w2D	 = (1/(2*pi*sigmax*sigmay))
	w2d*= exp( - (x*cos(theta) + y*sin(theta))^2/(2*sigmax^2)  )
	w2d*= exp( - (-x*sin(theta) + y*cos(theta))^2/(2*sigmay^2) )
	// create a suitable w2D graph to show the fit results and contour lines
 	FuncFitMD/NTHR=0/TBOX=768 MyGauss W_coef  w2D /D // and fit it
Function MyGauss(w,x,y) : FitFunc
	Wave w
	Variable x
	Variable y
	//CurveFitDialog/ Equation:
	//CurveFitDialog/ f(x,y) = (A/(sigmax*sigmay))*exp(-(x*cos(theta)+y*sin(theta))^2/(2*sigmax^2) -(-x*sin(theta)+y*cos(theta))^2/(2*sigmay^2))
	//CurveFitDialog/ Independent Variables 2
	//CurveFitDialog/ x
	//CurveFitDialog/ y
	//CurveFitDialog/ Coefficients 4
	//CurveFitDialog/ w[0] = A
	//CurveFitDialog/ w[1] = sigmax
	//CurveFitDialog/ w[2] = sigmay
	//CurveFitDialog/ w[3] = theta
	return (w[0]/(w[1]*w[2]))*exp(-(x*cos(w[3])+y*sin(w[3]))^2/(2*w[1]^2) -(-x*sin(w[3])+y*cos(w[3]))^2/(2*w[2]^2))
