Exporting multiple 2D waves
Hi all,
Basically, I'd like to export N-2D waves of an experiment into N-text files. Of course, I can just open the wave table, copy the 2 columns and past into a text file, but it is getting intense when I have few hundreds of waves.
I did some coding in the past, but I am totally new to Igor, so any help and advice will be much appreciated. Thanks!
hrodstein
Below is a routine that saves all 2D waves in the current data folder to disk.
But first . . .
If you are not familiar with the important concept of Igor symbolic paths, execute this and read the corresponding help:
DisplayHelpTopic "Symbolic Paths"
If you are not familiar with the important concept of Igor data folders, execute this and read the corresponding help:
DisplayHelpTopic "Data Folders"
Also, if you have not already done it, do the first half of the Igor Guided Tour which you can find by choosing Help->Getting Started.
Here is the routine:
Function/S SaveAllNumeric2DWaveToTextFiles(pathName)
	String pathName		// Name of Igor symbolic path
	String fileNameList = ""
	Variable index = 0
	do
		Wave/Z w = WaveRefIndexed("", index, 4)	// Next wave in current data folder
		if (!WaveExists(w))
			break				// No more waves
		if (WaveType(w) == 0)
			index += 1
			continue			// Skip text waves
		if (WaveDims(w) != 2)
			index += 1
			continue			// 2D waves only
		String fileName = NameOfWave(w) + ".dat"
		Save /P=$pathName /J /O w as fileName	// Save to text file
		fileNameList += fileName + ";"
		index += 1
	while(1)
	return fileNameList
mssmtrainee
Hi again there and thanks for the helpful code. I just have two quick questions:
First, I'd like to name my text files 1.dat, 2.dat, 3.dat etc. Is there away to convert an Integer into a String? (7th line from the end)
And second, to make the code work, I need to load my waves. Is there a way to load, let say 50 waves in the same time?
//Code provided by Igor-Exchange, user "hrodstein" 11/30/2011:
             //Save 2D waves to text files *.dat
//Modified by Vireak Yim 12/02/2011:
            // Extract points from waves, rearrange them into 2 columns, and save in a text file *.dat
	Variable index = 0
	do
		if (!WaveExists(w))
			index += 1
			index += 1
 		Make /N = (199,3)  Subwave     // Create an intermediate wave with 200 rows
 		Variable ind = 0
 		do
 			Subwave[ind][0] = w[ind][2]*10^9
 			Subwave[ind][1] = w[ind][0]*10^9	// Rearrange the data columns and convert them to nm to fit the pointwise requirements
			Subwave[ind][2] = w[ind][1]*10^9
		       ind += 1
		while(ind<200)
		String fileName = %index + ".dat" // Convert integer 'index' into string (trying to get 1.dat, 2.dat, 3.dat...)
		Save /P=$pathName /J /O Subwave as fileName	// Save to text file
		index += 1
	while(1)
	return fileNameList
Cheers,
awirsing
mssmtrainee wrote: First, I'd like to name my text files 1.dat, 2.dat, 3.dat etc. Is there away to convert an Integer into a String? (7th line from the end)
Sure, it's
num2istr
mssmtrainee wrote: And second, to make the code work, I need to load my waves. Is there a way to load, let say 50 waves in the same time?
Maybe you can start by modifying this function posted by Adam Light.
A
hrodstein
Execute this:
DisplayHelpTopic "Loading Waves Using Igor Procedures"
