newpath prompt directory location
Is there a way to set the 'starting' position for the newpath prompt? I picture something like pathinfo/s for the open command or forcing 'newpath path, globalPathString' to display a prompt even if globalPathString is valid.
More specifically, my code loads all files in multiple paths each selected by the user, and i want to use the user-selected paths as a starting guess when the code is executed the next time. The behavior of newpath under my windows xp system / Igor 6.22a is to use the last selected directory when undirected, or don't prompt for a path when directed...
Fabrizio
This works for me:
NewPath /O InitialPath, "C:Program Files"
PathInfo /S InitialPath	// Set initial path for next NewPath
NewPath /O DataPath	// Get the user's path
NewPath /O InitialPath, "C:Windows"
Thanks, that works indeed. I forgot to 'translate' my global string to a symbolic path for pathinfo.
- Fabrizio
