Error values in motofit
Genetic Optimisation Successful Fitting: YCumData to MOTO_NewGlblFitFunc V_fitIters = 420; V_Chisq = 96.7877; V_npnts= 162; V_nterms= 4; V_nheld= 0; V_logBayes = 65.7031 w[0] = 3001.7 +/- 0.249107 w[1] = 9.91829e-07 +/- 8.10371e-10 w[2] = 0.9985 +/- 0.000139441 w[3] = 199.641 +/- 0.164732 Genetic Optimisation Successful Fitting: YCumData to MOTO_NewGlblFitFunc V_fitIters = 420; V_Chisq = 96.7877; V_npnts= 162; V_nterms= 4; V_nheld= 0; V_logBayes = 65.7031 w[0] = 3001.7 +/- 0.249107 w[1] = 9.91829e-07 +/- 8.10371e-10 w[2] = 0.9985 +/- 0.000139441 w[3] = 199.641 +/- 0.164732 _______________________________ Global Fit converged normally.
while other functions do not, for instance:
Genetic Optimisation Successful Fitting: YCumData to MOTO_NewGlblFitFunc V_fitIters = 287; V_Chisq = 212.499; V_npnts= 162; V_nterms= 10; V_nheld= 0; V_logBayes = 0 w[0] = 28.0851 +/- 0 w[1] = 5.48056 +/- 0 w[2] = 3593.68 +/- 0 w[3] = 18178.4 +/- 0 w[4] = 3.41564 +/- 0 w[5] = 9.834e-07 +/- 0 w[6] = 1.65546e-10 +/- 0 w[7] = 1.35591e-09 +/- 0 w[8] = 9.91592e-12 +/- 0 w[9] = 200.196 +/- 0 _______________________________ Global Fit converged normally.
Here is the function for the function giving +/- values
Function ZrealQandlesU(w,frequency) : FitFunc Wave w Variable frequency //CurveFitDialog/ These comments were created by the Curve Fitting dialog. Altering them will //CurveFitDialog/ make the function less convenient to work with in the Curve Fitting dialog. //CurveFitDialog/ Equation: //CurveFitDialog/ f(frequency) = -1*(2*Cdl*frequency*3.14159)/(4*Cdl^2*frequency^2*3.14159^2+1/(RP^2)) //CurveFitDialog/ End of Equation //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ frequency //CurveFitDialog/ Coefficients 4 //CurveFitDialog/ w[0] = RP //CurveFitDialog/ w[1] = Qdl //CurveFitDialog/ w[2] = ndl //CurveFitDialog/ w[3] = RS Variable RP,Qdl,RS,ndl RP=w[0] Qdl=w[1] ndl=w[2] RS=w[3] return RS+ real(1/(1/RP +Qdl*(2*Pi*frequency*sqrt(-1))^ndl)) End
And the function that does not:
Function ZrealTlporosity(w,frequency) : FitFunc Wave w Variable frequency //CurveFitDialog/ These comments were created by the Curve Fitting dialog. Altering them will //CurveFitDialog/ make the function less convenient to work with in the Curve Fitting dialog. //CurveFitDialog/ Equation: //CurveFitDialog/ f(frequency) = transmission line //CurveFitDialog/ End of Equation //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ frequency //CurveFitDialog/ Coefficients 10 //CurveFitDialog/ w[0] = R1 //CurveFitDialog/ w[1] = R2 //CurveFitDialog/ w[2] = Ra //CurveFitDialog/ w[3] = Rb //CurveFitDialog/ w[4] = R0 //CurveFitDialog/ w[5] = Ca //CurveFitDialog/ w[6] = Cb //CurveFitDialog/ w[7] = C0 //CurveFitDialog/ w[8] = L1 //CurveFitDialog/ w[9] = Rsb Variable R1,R2,Ra,Rb,R0,Ca,Cb,C0,Rsb,x1,x2,L1 Variable/C pr,Za,Zb,lambda,Cl,Sl,Ztline R1=w[0] R2=w[1] Ra=w[2] Rb=w[3] R0=w[4] Ca=w[5] Cb=w[6] C0=w[7] L1=w[8] Rsb=w[9] pr = 1/(1/R0 - (sqrt(-1)*2*pi*frequency*C0)) x1 = R1 x2 = R2 Za = 1/(1/Ra - sqrt(-1)*2*pi*frequency*Ca) Zb = 1/(1/Rb - sqrt(-1)*2*pi*frequency*Cb) lambda = (pr/(x1 + x2))^(1/2) Cl = Cosh(L1/lambda) Sl = Sinh(L1/lambda) return Rsb+real(1/(x1 + x2)*(lambda*(x1 + x2)*Sl + (Za + Zb)*Cl + (Za*Zb*Sl)/(lambda*(x1 + x2)))^(-1)*(L1*x1*x2*(x1 + x2)*Sl + x1*(lambda*x1*Sl + L1*x2*Cl)*Za + x2*(lambda*x2*Sl + L1*x1*Cl)*Zb + (2*X1*x2 + (x1^2 + x2^2)*Cl + (L1/lambda)*x1*x2*Sl)*(Za*Zb)/(x1 + x2))) End
Any idea as to why this is?
December 15, 2011 at 02:14 pm - Permalink
December 15, 2011 at 03:21 pm - Permalink
I've looked into this and I've got some good and bad news.
THe bad news first. The code is determining the fit uncertainty by estimating the covariance matrix using a gradient technique (similar to the Levenberg Marquardt). This involves determining the Hessian (partial derivative of Chi2 w.r.t each of the parameters) followed by matrix inversion.
The code is having a problem inverting the matrix, probably due to numeric instability caused by the presence of some very small parameters (1e-12). I could probably condition the matrix better by scaling those values up, but it's not a high priority fix for me as you still get good fit parameters and it's not the prime output of the genetic optimisation. Following this analysis with a LM analysis may give you the fit uncertainties you desire, in this case.
THe good news is that you can speed your fits up a lot by choosing a population size multiplier of 10, and a tolerance of 0.01. The values you had in there were much too small and were making the fit take way too long.
Please note that the genetic optimisation itself does not use gradients.
December 16, 2011 at 12:48 am - Permalink
Curiously, running the levenberg method yielded this result:
Which doesn't look so useful ... I think that despite reporting values, that the inversion is again failing, probably due to the nature of my function.
I appreciated your advice about the fit variables. I did not realize that the population size was a multiplier! I have been adjusting popsize based on the number of coefficients that I was using. For some functions, this meant using popsize=400. Clearly, for 20 coefficients, that would actually generate a population of 8000, which slows things down a bit. I am going to read your documentation before asking any further questions in order to respect your time. :)
Thanks again
Matt
December 16, 2011 at 01:47 pm - Permalink
The fit result you posted looks like you have "Identifiability" problems. That's regression buzz talk for a situation where two or more of your fit coefficients are nearly (or actually) linearly dependent. That means that if you were to perturb one of the affected coefficients and hold it, then do a fit you would get a fit that is nearly as good as the original solution. In that case, the fitting algorithm can't distinguish the different solutions and the chi-square surface around the solution is very flat. That leads to those very large error bars.
Unfortunately, it's not something that is easily fixed. It's a mathematical problem, not a software or algorithm problem. Sometimes you can relieve the situation by adding more data points to cover some area in the coefficient space where the coefficients have different effects. Sometimes you can reformulate the model to reduce the number of coefficients.
December 20, 2011 at 10:20 am - Permalink
Moto_montecarlo(fn, w, yy, xx, ee, holdstring, Iters,[cursA, cursB, outf])function in the geneticoptimisation.ipf file. This may be able to assist in evaluating parameter uncertainties (but not in a global fit).December 20, 2011 at 02:33 pm - Permalink
December 21, 2011 at 11:41 am - Permalink
Matt
December 21, 2011 at 12:10 pm - Permalink
December 21, 2011 at 12:12 pm - Permalink
December 21, 2011 at 01:04 pm - Permalink
