For Loop to remove errors from multiple files
I'm new to Igor and have been trying to design a for loop to go through multiple files and 'nan' points that fall within a certain range. I'm assuming this needs two for loops running at the same time although I'm not sure.
I've got 30 files 'FILE_01, _02, _03 etc...' and in these files there are several thousand points, some of which need removing. I have the code below which cycles through the files, but I'm stuck at which point to include a loop to go through each wave looking for number <0 and removing them. I know this is a real beginner question but I'd appreciate any pointers!
Thanks.
function remove_errors()
variable i
string bin
for (i=1;i<=30;i+=1)
bin=num2str(i)
if(strlen(bin)==1)
bin="0"+bin
name="root:cdp_"+bin
ChrLie
I'm not entirely sure if I understood correctly, but it could be that you are trying to remove NaN's from your data?
If so, and your "files" were actually waves then you could execute the following function:
function RemoveNaNs(list)
	string list
	variable i
	string nextwave = ""
	do
		nextwave = stringfromlist(i, list)
		if (strlen(nextwave) == 0)
			break
		wave w = $nextwave
		w = SelectNumber(numtype(w) == 2, w,0)
	i += 1
	while(1)
say, if your waves of interest were named w1, w2, w3 you would execute:
RemoveNaNs("w1;w2;w3")
from the command line. In case of more waves you can use the WaveList - command to get a string of all the waves.
"NumType" in the above code identifies NaN's and SelectNumber can be used here a bit like an if-statement.
I hope this points into the right direction!
Cheers
C
chozo
Ok, first things first: You may want to put future code in <igor> </igor> tags, to make the code better readable by highlighting.
So now lets look at the first step of iterating through your files. You solution may work, but is very hardcoded to the specific case with the exact wave names (better call them 'waves', because 'files' make you think of stuff saved on the hard drive instead of loaded data in Igor) and count of your waves. How about a way to process the waves on demand for this simple task? I would do this by utilizing the execute command button in the data browser. Like so:
Function remove_errors(my_wave)
wave my_wave
//do stuff with my_wave here
Now you can select all the waves you need to process and hit the 'Exec. Cmd.' button. Write 'remove_errors(%s)' in there and hit Ok (%s is a placeholder where the actual wave name will be pasted). All waves you have selected will be processed with you function. No need for loops and hardcoding wave names (leave that until you have really complicated tasks, and even then hardcoding stuff can always be avoided).
Now to the actual task of inserting NaNs. This is quickly done in one line. Just use 'my_wave = my_wave[p]<0 ? NaN : my_wave[p]', to replace all values smaller than zero with NaN. This expression is a shortcut for an if-else statement. You may want to read more about it in the help browser, but here is what it basically does: The equation automatically goes through all points of the wave; no need for a loop. The current point is expressed by the counter p. First cones a question: Is the current point <0? The answer decides if the value before (here NaN) or after the ':' is picked. The full function will look like this then:
wave my_wave
ChrLie
actually, regardless, whether the task is to replace NaN's by zero's or to set negative values to NaN's:
I was just curious which 1-liner runs faster:
w = (NumType(w)==2) ? 0 : w
(assuming the task is NaN's to 0) runs about twice as fast compared to
chozo
ChrLie wrote: actually, regardless, whether the task is to replace NaN's by zero's or to set negative values to NaN's:
Hmm, interesting that it makes such a huge difference. I guess it has something to do with what is written in the help file:
Unlike the ? : conditional operator, SelectNumber always evaluates all of the numeric expression parameters val1, val2, ...
SelectNumber works in a macro, whereas the conditional operator does not.
thunderstruck71
ChrLie wrote: I'm not entirely sure if I understood correctly, but it could be that you are trying to remove NaN's from your data?
	string list
	variable i
	do
			break
		wave w = $nextwave
	i += 1
	while(1)
Cheers
C
Thanks for the help. Actually what I was trying to do was remove negative numbers from several waves, so actually turn some values into NaNs. I've solved it now using two different functions:
function remove_wave_errors(wave1)
wave wave1
variable i,j=numpnts(wave1)
	for (i=0;i<j;i+=1)
		if(wave1[i]<0)
		wave1[i]=NAN
the above function is executed within this function:
function Remove_cdp_errors()
variable i
string name,bin
	bin=num2str(i)
		if(strlen(bin)==1)
		bin="0"+bin
	name="cdp_"+bin
wave source_data=$name
	 remove_wave_errors(source_data)
thunderstruck71
chozo wrote: Ok, first things first: You may want to put future code in <igor> </igor> tags, to make the code better readable by highlighting.
wave my_wave
wave my_wave
I didn't know that the Exec Cmd button could be used in this way. Your way seems a hell of a lot easier than the 2 functions I've got to achieve the same result. Thanks.
aclight
wave wave1
	for (i=0;i<j;i+=1)
		if(wave1[i]<0)
		wave1[i]=NAN
This will work, but as chozo pointed out before, this will be much faster:
	wave wave1
	wave1 = wave1[p] < 0 ? NaN : wave1[p]
If you're going to be doing much coding, it's best to get familiar with wave assignment statements sooner rather than later, because they are faster and will make coding a lot easier. For more information, execute the following command on Igor's command line:
thunderstruck71
wave wave1
	for (i=0;i<j;i+=1)
		if(wave1[i]<0)
		wave1[i]=NAN
	wave wave1
Thanks. One of the reasons I needed a function like the on I've got working is because I'll potentially be doing it over and over with lots of data, so although highlighting the files and using the Exec Cmd button is quick, long term being able to execute the function will knock some time off the task.
aclight
Sure...it sounds like using a function that can fix the errors on all waves with a certain name pattern automatically is the way to go here. I was just pointing out that chozo's way of actually removing the errors was faster than your way. If your waves are not very long then you probably won't notice any difference in performance, but if you are operating on lots of long waves it's always nice to have things go as fast as possible.
If you ever get to writing assignment statements for multi-dimensional waves, using nested for loops gets to be a real drag and can be error prone. So knowing how to "correctly" write a wave assignment statement can be very helpful.
chozo
Ok, maybe you want to reduce the hardcoded stuff in your other function a bit, like aclight was already hinting? Like so:
Function Remove_cdp_errors(NameMatch)
string NameMatch
string names = WaveList(NameMatch+"*",";","")			// generates a list with all waves beginning with 'NameMatch'
variable i
	for (i = 0; i < ItemsInList(names); i += 1)		// go through the list
		wave source_data=$(StringFromList(i, names))
Call 'Remove_cdp_errors("cdp")' to get the job done. Now you are free to choose the wave name pattern. Getting the function to work for all waves in a folder would make it even shorter (by removing all the NameMatch code).
