"step"-function
Here, I just would like to create a step function wave that depends on x. I wonder why it displays 0 for both conditions? It shouldn't! Any help would be appreciated. Thanks!
#pragma rtGlobals=1		// Use modern global access method.
Function CreatingBConeData()
	KillWaves/A
	Variable theta = 39.5					//Semi-included angle of cone (generally ~39.5 deg)
	Variable R = 40e-9					//radius of spherical tip
	Variable b = R*cos(theta*pi/180)
	Variable eta = 0.5
	Variable hstar = (b^2)/(2.*R)
	Variable Stif = 1000
	Make/N=(100,1) Phorce; SetScale/I x, 0, 1e-6, Phorce
	variable index
	for(index=0; index<100; index+=1)
		if(index<50) 		//if(x<0.5e-6)
			Phorce = (4/(3*(1-eta^2)))*sqrt(R)*Stif*x^1.5
		elseif (index>50)		//elseif(x>0.5e-6)
			Phorce = 0
	print hstar
End.
aclight
I think this is closer to what you are looking for:
	Variable eta = 0.5
	Make/O/N=(100,1) Phorce = 0; SetScale/I x, 0, 1e-6, Phorce
	variable index
	Phorce = (p < 50) ? (4/(3*(1-eta^2)))*sqrt(R)*Stif*x^1.5 : 0
	print hstar
You might want to read up on wave assignment. To do that, execute the following command on Igor's command line:
s.r.chinn
mssmtrainee:
Another simple one-liner step-function is using just a logic multiplier factor:
Make/O/N=(100) Phorce = 0; SetScale/I x, 0, 1e-6, Phorce
Phorce =  (4/(3*(1-eta^2)))*sqrt(R)*Stif*x^1.5 * (p<50)  // logic multiplier factor on index
You could also use (x<0.5e-6) as the multiplier. Note that if you don't really need Phorce defined as a 2D wave (albeit 100 by 1), you are probably better off with a 1D wave as shown.
hrodstein
To answer your original question of why the output is all zero, this:
	if(index<50)
	elseif (index>50)
		Phorce = 0
should be this:
	if(index<50)
		Phorce[index] = (4/(3*(1-eta^2)))*sqrt(R)*Stif*x^1.5
		Phorce[index] = 0
Notice the use of "[index]" to set a particular point in the wave. You were setting every point in the wave each time through the loop.
I also changed your elseif to if because your code did nothing for index==50.
Even with my changes, I still get all zeros. If you change the complicated expression to 1, you will see that the basic logic is correct - you get a square wave. Thus I conclude that your expression is returning zero for all x.
aclight
hrodstein wrote:
	if(index<50)
		Phorce[index] = 0
There is an "x" in the calculation of the Phorce value. That's why I used a ternary assignment in my original answer.
Here is code that uses the loop and gives the correct result:
	Variable eta = 0.5
	// Using a loop for wave assignment (this is the slow way)
	variable index
		if(index<50)
			Phorce[index] = (4/(3*(1-eta^2)))*sqrt(R)*Stif*pnt2x(Phorce, index)^1.5
			Phorce[index] = 0
	// Using a proper wave assignment statement (this is the faster way)
//	Phorce = (p < 50) ? (4/(3*(1-eta^2)))*sqrt(R)*Stif*x^1.5 : 0
	print hstar
s.r.chinn
There is something interesting happening here. With Howard's code I get the proper(?) non-zero result for
	if(index<50) 		//  if(x<0.5e-6)
		Phorce[index][0] = (4/(3*(1-eta^2)))*sqrt(R)*Stif*x^1.5
		Phorce[index][0] = 0
Note the second wave dimension; remember that Phorce was defined as a 2D wave by mssmtrainee. I agree with Adam about the ambiguous value of 'x' in the wave element assignment, but it somehow seems to work with this version. Perhaps the 'index' value forces the proper scaled assignment of 'x' without explicit use of pnt2x().
hrodstein
Apparently the use of 2D syntax (phorce[index][0]=) cause x to be set when the righthand side is executed but the use of 1D syntax (phorce[index]=) does not.
Since this is a 1D application, a 1D wave should be created. So this:
should be changed to:
Make/N=(100) Phorce
