Structure element as path input to NewPath operation
The compiler throws an error ("Expected a keyword or an object name") when a structure string element is used to input the path to NewPath:
Struct structJTG_MFLa s
NewPath /O/Q/Z spLoadNoteFunc, s.sPathToFiles
The error highlights the period between "s" and "sPathToFiles".
The structure and sPathToFiles have previously been defined as:
Structure structJTG_MFLa
	String sFileNameList		//semicolon separated list of selected files
	String sPathToFiles		//colon separated path to disk files
	Variable vKillWaves //1 == kill waves, otherwise don't; message to file loader to kill waves when done
EndStructure
This can be worked around with...
String sPathToFiles = s.sPathToFiles
//create new symbolic path
NewPath /O/Q/Z spLoadNoteFunc, sPathToFiles
but the error from the use of a structure element is unexpected (for me, at least). Am I missing something?
Jeff
Try using the following statement instead:
NewPath /O/Q/Z spLoadNoteFunc, ""+ s.sPathToFiles
The Igor compiler often has difficulties compiling operations that expect string parameters when you use a string element of a structure. By concatenating an empty string to the beginning of the structure string field, you allow the compiler to recognize that you are in fact providing a string.
This works. Now that I see the answer, I think it has been mentioned here (or on the mailing list) relatively recently. Thanks.
