Trim leading whitespace
" !]L1lU22ut@#% T*)rM! 8" becomes "!]L1lU22ut@#% T*)rM! 8"
where the leading and internal whitespace can be any form of whitespace (blank, tab, etc.). I don't think that Igor has a trim function to remove leading or trailing characters. Is this correct? I am no regular Regular Expression person, but (through trial and error) I arrived at the following, using split string:
splitstring /E="(\\s*)([[:ascii:]]*)" sString, sFirst, sSecondwhere sSecond returns the desired portion of the input string. Is this a reasonable solution to the problem or is there a better way?
Also, ideally, trailing whitespace would be removed as well, but I haven't figured that out using Regular Expressions.
Jeff
March 27, 2012 at 03:28 pm - Permalink
That is certainly the bullet proof way to go. It is my back up if the splitstring fails me. Thanks for the response.
I wonder if there are any comments on the regular expression method. The archives & help files didn't cough up any useful insights on this question.
March 29, 2012 at 06:34 am - Permalink
http://www.codinghorror.com/blog/2008/06/regular-expressions-now-you-ha…
I wrote SplitString and the regular expression routines. I use them only if straightforward approaches are insufficient. Leading and trailing spaces are pretty simple to remove using easily understood foolproof code like the above.
Regular expressions are great until they don't work for some mysterious reason. Then they're a pain.
March 29, 2012 at 01:26 pm - Permalink
While I agree with Jim's thoughts on regular expressions, I believe his code will work only with spaces. It's possible to expand his code to handle other whitespace characters, of course, but the problem is that you'll need to add these cases explicitly. But what if you get exotic stuff like a nonbreaking space? I don't like dangling ends like that, even though the odds are minuscule.
So, while filtering for tabs and spaces only wouldn't be too bad, and might not hit the threshold for RegExps, I would probably use one anyway just for the peace of mind that it should handle *any* whitespace character.
It would be tempting to use (note the use of the '^' and '$' anchors)
SplitString /E="^\\s*(.*)\\s*$" MyString, noTrailingOrLeadingSpacesBut it won't work because the trailing whitespace will match the '.*' pattern, so the '\\s*' at the end will never be matched. We've got a clear problem definition and a deceptively simple RegExp, but we're already running into problems. That's the two problems for you ;).
So, what do I propose? Simply make a slight change to Jim's code, like this:
Which, I think, is still sufficiently in line with Jim's simple answer, while also satisfying my tendency to fret over obscure edge cases ;).
March 29, 2012 at 11:31 pm - Permalink
I believe the following does what you want (trimming both leading and trailing whitespace):
SplitString/E="^\\s*(.*?)\\s*$" testString, trimmedStringI assume you don't need to capture the leading whitespace as you did in your original question. As 741 mentioned, you should use the leading and trailing anchors in your expressions also.
March 30, 2012 at 06:39 am - Permalink
March 30, 2012 at 06:41 am - Permalink
Is there a possibility to include a replace string using Regular Expressions in IPV7?
April 4, 2012 at 10:44 am - Permalink
