Sparse markers menu with the "markers" plot option
jdombard
Thu, 04/26/2012 - 11:15 am
I often compare several data sets on the same graph and plot one of them as markers (numerics vs experimental data).
The "Sparse Markers" menu only appears when I select the "Lines and markers" plot option. I think that it would be great that it also appears for the plot menu "Markers".
Right now, the way I found to plot sparse markers without any line linking them is to plot my data set as lines and markers and set the line in white color. There might be a better way but I have not found it yet.
Thank you in advance.
Jérôme
April 26, 2012 at 12:24 pm - Permalink
Since my post has been moved from the wish list section, may I conclude that you do not consider as a valid option to set the "sparse marker" menu inside the "markers" plot menu?
Using the "line and markers" menu and set the size of the line at zero is, in my opinion, a roundabout mean.
April 27, 2012 at 08:46 am - Permalink
I moved it back; it *is* a wishlist item we should consider (and a "general" question, too).
April 28, 2012 at 09:30 am - Permalink
April 30, 2012 at 09:48 am - Permalink
