ProgWinXOP on Mac
I have downloaded the ProgWinXOP package for my Igor Pro 6.10 on (unfortunately) MacOS 15.8.
I have copied the files to the extensions folder (and some others to try). When executing a macro that uses the ProgressWindow command, I always get the same error "expected wave name, variable name, or operation. I guess, I have not installed the package properly.
Which is the correct folder to copy the files? do I have to do anything else?
Thanks in advance.
F
Install the XOP in the "Igor Extensions" folder in your "Igor Pro User Files" folder. To learn about those folders, execute this in Igor:
After installing, restart Igor.
BTW, it is possible to implement a progress window without XOPs:
May 22, 2012 at 05:10 pm - Permalink
I downloaded again the Mac version of the files.
I have then copied the files in the "Igor Extensions" folder in my "Igor Pro 6 User Files" folder. Same problem.
Copied also on the "Igor Extensions" folder in my Igor "Igor Pro 6.1 Folder" in the "Applications" folder. Same problem.
I also tried to do the same but just copying the alias of the files and not the files themselves. Same problem.
By installing the files, I understand just copy them in the folder, right?
Is there anything I am missing?
Thanks again,
F
May 23, 2012 at 03:49 pm - Permalink
I don't think so.
I'm not sure where you got the XOP from. I downloaded it from the WaveMetrics FTP server. That file is very (13 year!) old and PowerPC only. It will not run on an Intel Macintosh.
I thought there was a newer version but I am unable to find it.
You might consider asking on the Igor mailing list. One of the authors of ProgWinXOP was seen there recently.
May 23, 2012 at 05:17 pm - Permalink
For new code you may prefer to use Igor's built-in progress window feature. For details execute:
September 15, 2012 at 02:41 pm - Permalink
