Loading partial columns from ASCII as wave
1) Only read in part of a column (after row 119 on the files attached) this can easily be achieved using loadwave or xlloadwave.
2) Read in the rest of the column after this row, however the number of points within a column is not constant (it's 88, 217 and 200 points in the attached files) and it would be preferable not to create a wave with NaN values or edit the script of a LoadWave command each time I wanted to use this function!
Is there a way of bypassing the "numlines" value from the /L flag of the LoadWave command that could be used?
Thanks in advance,
Jon
Passing 0 for numLines means "auto" and will load all of the rest of the lines in the file. This seems like what you need.
July 30, 2012 at 10:49 am - Permalink
It sounds like you want to read in the header info (first 119 lines) and then the first 3 columns of actual data following the header. If that is the case then you probably want to use LoadWave twice, first for the header and then for the data.
Something like:
should get the header. And something like:
should get the data.
Note the difference in the /L flag. In the first instance you read 119 lines starting from line 0. And in the second, you start at line 120 and read until no more data is found, that is you let Igor determine where the end of the data lies.
I seldom use loadwave; I am not an expert. Others may have better ideas. The two LoadWave commands shown above were obtained by setting up the operation using the LoadWave dialog from the Data menu.
July 30, 2012 at 11:14 am - Permalink
August 27, 2012 at 12:52 pm - Permalink
