SetDataFolder using DREF in for loop is always one iteration behind
function RelativelyColorGraph()
string trl=TraceNameList("",";",1), item
variable items=ItemsInList(trl), i
Variable ExperimentalValue = 1 //This determines what characteristic to base the coloring
colortab2wave YellowHot256 //Assiging the color spectrum to use
wave/i/u M_colors
variable VariableOfInterest, UniqueColors = DimSize(M_colors, 0) //Extracts number of rows associated with M_colors
for(i=0;i<items;i+=1)
wave Extracted_Data, ww = WaveRefIndexed("",i,1)
DFREF FolderPath = GetWAvesDataFolderDFR(ww)
SetDataFolder FolderPath
VariableofInterest = Extracted_Data[ExperimentalValue] //Extracted_Data is a wave containing the important characteristics
Modifier = Round(UniqueColors*VariableOfInterest/Bounds) //Linear scaling to determine the color of the wave
item=stringfromlist(i,trl) //Determines which trace of the graph to modify
ModifyGraph rgb($item)=(M_colors[Modifier][0],M_colors[Modifier ][1],M_colors[Modifier ][2])
ModifyGraph mrkStrokeRGB($item)= (M_colors[Modifier][0],M_colors[Modifier ][1],M_colors[Modifier][2])
killwaves/z M_colors
This code works fine - apart from one glaring issue. After
SetDataFolder FolderPath the "CurrentDF" is changed according the debugger - but when Extracted_Data is accessed it uses the previously assigned data folder. For example: if I start in "Root:" where no Extracted_Data wave exists, VariableOfInterest = NaN. In the next iteration VaribleOfInerest = [value associated where i = 0] and so on.
Am I missing something obvious? Is this an error in IGOR Pro? Or is there a better way to do what I am trying to do?
Regards,
- Willy
statement to after the SetDataFolder call.
Execute this to read the help for the Wave statement and note the part that starts "A Wave statement has both a compile-time and a runtime effect":
It is better to not change the current data folder if you can avoid it. A better approach would be to dispense with the SetDataFolder command and change it to:
July 31, 2012 at 09:53 am - Permalink
July 31, 2012 at 10:21 am - Permalink
