Create wave name from a variable
Very easy problem for you! I tried to find the answer everywhere I could but it still wrong...
I want to call a wave name somewhere in my program like this:
Function test (x)
Variable x
Wave wavename+x
And if I write "test (12)", I want to call the wave "wavename12"...i'me sure it's very easy, but I tried with "num2str" and everything like this but there's no way to work....
Thanks for your answer!
Marc
Do it like this:
Function test (x)
Variable x
Wave mywave = $("wavename"+num2str(x))
... // do something with mywave
checkout
The syntax is basically
Function myFunction(str)
string str
wave wv = $str // reads the name of the wave from the *contents* of str
wave wvv = $"myWave"
wave wvv = $("myWave" + "mySuffix")
In addition to the documentation referenced by thomas_braun, you should check these out:
In case you are unfamiliar with DisplayHelpTopic, all you need to do is copy the command line, paste it into Igor's command line and press Enter.
The first discusses various direct solutions to your problem; the others are more general.
Thanks a lot for all your answers!
I thought so it was something with references but can't deal with it!
