killwindow utilizing a loop
Hi, I wrote the following procedure to delete all the subwindows in a window named "Panel". The names of the subwindows are like "Panel#G0", "Panel#G1"...
When i run the procedure, the pop-up window appears "window while executing KillWindow, the following error occured: Expected window name".
I am quite confused with this error, so how can i handle with this problem?
Thanks in advance for help!
function button_clear(ctrl):Buttoncontrol
  string ctrl
  variable subwinnum
  variable i
  string/g childlist
  string subwn, subwnname
  childlist=Childwindowlist("Panel")
  subwinnum=ItemsInList(childlist)
  for(i=0; i
jtigor
Also subwn isn't being incrementing. Move the sprintf inside the for loop or use something like the following.
  for(i=0; i<subwinnum; i+=1)
    subwnname="Panel#G"+num2str(i)
    killwindow subwnname
Finally, the statement
subwinnum=ItemsInList(childlist)-1
should be
JimProuty
This version works:
	string ctrl
	String panel= WinName(0,64)	// top panel
	String childlist=Childwindowlist(panel)
	Print childlist
	variable subwinnum=ItemsInList(childlist)
	variable i
		String subwnname= panel+"#"+StringFromList(i,childList)
		killwindow $subwnname
	KillWaves/A/Z/F
