I've got a wave with approximately 30 columns and 1000 rows that I want to act on. I'm used to using 'numpnts' but in the help it refers me to dimsize to define number of data points. However it's still not clear which dimnumber to use in the for loop. I'm not sure what 'Layers' or 'Chunks' refers to and both 'rows' and 'columns' don't seem to do the job.
Any ideas?
and run it by executing:
However, depending on what you want to achieve, maybe this can be done without a loop.
September 27, 2012 at 03:44 am - Permalink
By not doing the job I mean that specifying dimnumber 0 or 1 edits either the entire first column (in the case of 0) or just the first 30 rows of the first column (in the case of 0). What I'm trying to do is go to every single data point and any zeros. I've just tried this below, which works on the first 30 rows of every column...
I think what I need to do is use a nested for-loop, which I've tried above but it doesn't work on the whole matrix.
Thanks.
September 27, 2012 at 03:59 am - Permalink
that you can do like this (taking wave aa as example):
the "? : " means if any point of aa==0, set it to NaN, otherwise leave as is
September 27, 2012 at 04:06 am - Permalink
I think your indexing is wrong, try:
if (data[jj][ii]==0)
data[jj][ii]=nan
with ii you should be running though columns, but you're going through rows.
September 27, 2012 at 04:15 am - Permalink
Thanks, that's worked perfectly. Being newish to IGOR I tend to end up trying to do everything the long way!
September 27, 2012 at 04:20 am - Permalink
