Baseline Removal Using TN020 procedures.ipf - Error
I am trying to use the TN020 peak measurement procedure for baseline removal as described here: http://www.wavemetrics.com/products/igorpro/dataanalysis/peakanalysis/b…
However, when I run the procedure and click Init Baseline Fit, I get the error "got "g_w" instead of a string variable or string function name". Has anyone run into this problem?
[quote=MJVU]I am trying to use the TN020 peak measurement procedure for baseline removal as described here: http://www.wavemetrics.com/products/igorpro/dataanalysis/peakanalysis/b…
However, when I run the procedure and click Init Baseline Fit, I get the error "got "g_w" instead of a string variable or string function name". Has anyone run into this problem?[/quote]
You need to first select "Initialize Most Everything" in the same menu.
Those menus are designed to be used in a top-down manner.
