Fit with constraints using a parameter wave
Function N2_qcq(w,x) : FitFunc // quadratic cubic quadratic fit Wave w // Variable x if( x<w[0]) return w[1] + w[2]*(x-w[0]) + w[6]*(x-w[0])^2; elseif( x <w[3] ) return w[1]*(x-w[3])/(w[0]-w[3]) + w[4]*(x-w[0])/(w[3]-w[0]) + (w[2]-(w[4]-w[1])/(w[3]-w[0]))*(x-w[0])*(x-w[3])^2/(w[0]-w[3])^2+ (w[5]-(w[4]-w[1])/(w[3]-w[0]))*(x-w[0])^2*(x-w[3])/(w[3]-w[0])^2; else return w[4] + w[5]*(x-w[3]) + w[7]*(x-w[3])^2; endif end
I'd like to pass linear constraints (upper/lower boundary) to funcfit using /c=Constraints where Constraints is a text wave
What is the appropriate syntax to apply constraints on w[i] ?
Replace "lowerlimitofw[0]" with an actual number or and expression that can be evaluated from Igor's command line.
You can read about the formation of the constraint expressions by executing this Igor command:
DisplayHelpTopic "Fitting with Constraints"
And you can use the Curve Fit dialog, entering the constraints in the Coefficients tab, and see how the dialog forms the text wave.
October 17, 2012 at 12:30 pm - Permalink
or something like
October 17, 2012 at 01:53 pm - Permalink
The symbols like "K0" are special symbols that are interpreted by the curve fitting code to stand in for coefficient wave elements. They will work regardless of the name of the coefficient wave's name.
From the help topic I referenced earlier, but in a subsection:
DisplayHelpTopic "Constraint Expressions"
"In the expressions the symbol Kn (K0, K1, etc.) is used to represent the nth fitting coefficient. This is like the Kn system variables, but they are merely symbolic place holders in constraint expressions."
October 18, 2012 at 09:11 am - Permalink
